Not able to access ABS and SCCM modules in Forscan for Cruise Control Mod
Rduyve
Reed
2023 Maverick XLT Hybrid (Lux/BAP/CP360)
Only about half of the modules are showing up for me. I have access to BdyCM, but I can't find ABS or SCCM! Any suggestions?
I have a hybrid xl, and I'm adding these parts:
-SW-8576 (Switch Assembly Control)
-SW-8579 (Switch Assembly Control)
-LB5Z-13341-BA (Turn Signal Switch)
-FORScan OBD2 Adapter USB ELM327 Scanner (Auto Switch)
- FORScan V1.5 OBD2 Scanner (Manual Switch)
Neither of these FORScan modules could recognize all the modules.
The Weatherman
Dean
KY
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
Since you purchased as scanner with a manual switch, you will need to configure FORScan for a manual switch and make sure you switch it when it tells you if you want to see all the modules.
Rduyve
Rduyve
Reed
Thanks for the advice, how do I do that? 😀
Automate
