Noco Boost Plus battery jump starter?
cmachouse05
Bay City, MI
Ford Maverick XLT
Would it be worth it to purchase this item and store it under the back seats for use if my hybrid has a dead battery?
Carlitos_92
Yes, yes, a million times yes.
I got this one because it is a little bigger and has USB-C, but I keep it under my back seat:
https://a.co/d/0g2KRrHI
And I don't even have a hybrid. :)
CurtisB
2023 Maverick XLT Hybrid
I have a similar one. It is required to charge it once a month to keep it in warranty. Only used it once when the Maverick killed my DieHard Gold flooded battery. I feel confident that I will be able to drive the Maverick should/If it happens again. However, I now have an AGM battery.
Ozarkbeard
Yes. I keep a NOCO jump box under the backseat by the battery. It's great because it has a USB charging port for mobile devices and also a flashlight. I've used both during an extended power outage. They're also good for jumping someone else's car without having to line up two cars so jumper cables will reach. Much safer.
Set a calendar reminder on your phone to check the jump box charge every 6 months. However you should probably be able to go a year between maintenance charges.
Bwicka
Lakeside,ca.
These are the best things since sliced bread and round tires , if you have a gas vehicle should be carrying one in each car!
Daughter had to call aaa the other day , already adding one to her Christmas list !
