Irone
Ean
2023 Maverick Lariat
Can you install a role up tonneau cover with that setup?
itzJack
itzJack
Jack
Stockton
Ford Maverick 2023 XLT
Sorry I was a little late in replying but a roll up tonneau would not fit the set up. I went ahead and got myself a Retrax cover and placed it on top of the frame support brackets.
mdl20813
Idaho
Cactus Gray Maverick XLT
when you say “setup” are you meaning the rack? If so, then yes you can depending on the tonneau and which mounting brackets you get for the rack. I run the same rack in 14” height with a Sentry CT hard roll up. Requires you to notch the tonneau rails and have the “wide wing” brackets from Xtrusion Overland but mine works just like it did before I added the rack.
