Music sound quality over 20 volume
Cabiles1
Kenneth
SF
2024 Ford Maverick XLT Hybrid
Anyone else experience sound quality issues when you turn your volume past 20? When I do so, my front speakers cut in and out.
Cabiles1
Cabiles1
Kenneth
SF
Replace speakers if you want to listen at high volume.
The stock speakers are trash. but they’re not related to my current problem. The issue was the plug and play harness for my amp. I removed it and the issue went away.
Jamsandolina
Samuel
What plug and play harness were you using? Did you find the reason it was causing the issues?
Cabiles1
Cabiles1
Kenneth
SF
I’m using a basic harness from plugnplaykits.com
Emailed the company for advice. Hopefully he has a solution. Otherwise I'm back to the drawing board.
Ford Maverick Music sound quality over 20 volume IMG_4575
Jamsandolina
Samuel
Interesting. I'm about to start my audio upgrade. I have a kenwood kac-m1814 4 channel amp that I'm gonna use to power my speakers. I saw that hoel company offers a plug and play harness as does a company named LC something or other. My system is gonna be a basic one.....components up front and 4's in the rear all powered by that kenwood amp. I'm just trying to figure out how hard of an install it will be installing the dash tweeters.
Sea48!
Les
San Diego
Mazda 3
yes, anything over 20 sounds horrible! I am about to upgrade the front speakers and see if that helps, then maybe add an amp. The factory speakers don't have a lot of range.
May want to go ahead and start investing in Beltone :LOL:
Mdavis
Michael
2024 Maverick XLT
The dash tweets aren't that bad. Remove the grill, AND the a pillar trim, it has a tab that locks into the grill. The tweeters themselves have 3 tabs that just need to be pushed open a bit and they pop out. I dropped new wire down the hole for the tweeters. Installed the passive crossovers behind the dash. You can access that by dropping the glove box. Running Morel separates up front. Put Morel 4" coaxial in rear just for fill. Infinity 5 channel amp that also feeds the 2 JL subs under the back seat.
Ford Maverick Music sound quality over 20 volume IMG_1373
Ford Maverick Music sound quality over 20 volume IMG_1371
Ford Maverick Music sound quality over 20 volume IMG_1372
Ford Maverick Music sound quality over 20 volume IMG_1374
CurtisB
2023 Maverick XLT Hybrid
If you have the stock system (Non-Bose) then yes, anything over 15 sounds horrible. Speaker and amp upgrade will give you a balance sound at half the volume needed.
CurtisB
You ecoboost guys make me jealous of your stereo upgrades!! Solid job my man!!
Jamsandolina
Samuel
Awesome.....thanks. were you able to drop down new wire on the driver side dash tweeter easily too? Where on the oem front speaker wire does the tweeter wire connect to the front door speaker wire? Did the Morel tweeters just drop into the oem tweeter location or was there alot of modifications needed? Thanks
Cabiles1
Cabiles1
Kenneth
SF
This looks so sick. I’m sure it sounds even better. Installed an 8 in the back. But my hybrid model prevents the addition of another. Great work!
Ford Maverick Music sound quality over 20 volume IMG_4548
