MPG Difference Between Hybrid Instrument Cluster and Fuelly App
DaVicar
Hendersonville NC
2023 Subaru Crosstrek Limited, 2023 Maverick Lariat hybrid, Alto Blue, BAP
Wondering if anyone is noticing a 4-5 MPG difference between the Fuelly app and the Trip screen on the instrument cluster display. In my case, the app is always showing the lower figure. I saw on the forum a while ago that there is a way to adjust the vehicle's mile setting, but I hesitate to fool around with it until I get some more readings from others.
Anyway, just an FYI, at 6,234 miles, my 2023 Lariat is showing 41.5 average MPG, best is 49.8 MPG. Here in western NC, with my average price/gallon $3.13 (since 5/23), average price/mile $0.075. (per Fuelly app.)
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
My last fillup had the biggest difference: (24 hybrid).Computer read 48MPG while hand calc was 45.7. Sometimes it is right on; but it never has under estimated the MPG. FYI I use 91 octane and enjoy trying to get the Max/ MPG as possible. This fillup was about 100% local driving.
The Real Maverick
Jack
It's a commonly accepted value that with the factory settings the dash will read 5% high on average.
So many owners (like 90%) report this that they probably did this on purpose to make those that don't manually check feel better.
Probably there is some standard that says trip computers must be +/- 5% of actual and they went with the + 5%. It's not random.
You can adjust this value down via engineering test mode. Called "AFE bias" or "average fuel economy bias".
you can adjust in 0.1% increments.
so for 5% bias down, you need 50 bias points. Many users are happy with a setting of 950/1000. Some like 940/1000 better.
I started with 950/1000 but as lots of time passed, 940/1000 is true to actual. That's 6% downward adjustment.
HTH,
DaVicar
DaVicar
Hendersonville NC
HTH,
OK, thanks for this. I reset mine to 940 to start.
SFB
Daniel
Fullerton California
2019 Ranger Crew Sport XLT
I have a 19 Ranger, I check my mileage with a calculator and compare with truck computer, hand calculator always is 2 to 4 mpg lower than truck readouts. Looks like Ford fudges a bit.
DaVicar
DaVicar
Hendersonville NC
Did it turn out to match the pumped gas now?
The actual number was 943, and came close to about 1 -2 actual mpg. A few pounds of tire pressure difference will cause some change.
