Missing lighter cover in 2024
Ozarkbeard
Hockeyfish11
Ed
2024 Maverick
You asked, 2007 F-150 and still drive it. No lighter, but 2 covered receptacles
Hockeyfish11
Ed
2024 Maverick
Cheapest solution is to go to Temu.com. For less than $5.00 you can order a lighter or blank cover. Some have humorous quotes like “Fire middles”.
Already did Aluminum “”Eject” cover
sapperforward
Rich
CT
2024 maverick lariat
My 24 XLT has covers on both power points (one on the back of the center console for the rear seat passengers, one on the dash). Since I don't have pushbutton start like Bob S., the one on the dash is in a different spot tho - it is on the right, while the USBs are on the left where your push button start is.
Question - what is the switch between the 12v and the USB? I don't recognize that icon at all.
Back window
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
my 23 came with a cover but I still got a prettier one and this would work for you as well Hocketfish11
Ford Maverick Missing lighter cover in 2024 IMG_5490
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
My just received my Maverick. First vehicle I ever received w/o lighter or lighter cover.
All Mavs come with the "lighter" receptacle, so you're not looking in the correct dash and/or rear seat area (depending on your trim level). Others have posted images showing where the receptacle is. The cover is an integral part of the receptacle, so you need to replace the whole assembly. I had this break on a Fusion that uses the same part, and it was really expensive for what it is - I think it was around $75 at the dealer.
OK OK OK I just checked my 2022 and WALLA I found my cover hiding. It is hinged and when it's not covering the hole it is up against the dash and cannot be seen but it can be felt and lowered down until it covers the hole. It does not fall down by itself.!!!! MAYBE YOURS IS ALSO HIDING?
