GarryB
I frequently post honest reviews so people can make an infomate decision about products I've purchased for my 2025 Maverick hybrid.
I recently purchased and installed a set of @Maxzina Ratchet Straps from Amazon Canada and I couldn’t be more satisfied. These straps are permanently mounted into the bed liner using the provided bolts. These are incredibly convenient and always ready to use so no more fumbling around with loose tie-downs and untangling them...
The installation was straightforward, and once secured, the straps feel rock-solid. The ratcheting mechanism works smoothly, and the build quality is top-notch.
I read some reviews of people having difficulty with the provided bolts but I had zero. I couldn't use an allen key I ended up using an impact drill with zero difficulty and stronger than the originally installed hooks bar none. The only issue I had was having to move the clamp that holds my trifold over about 1 inch.
I also appreciate the fact that these straps blend in nicely with the Maverick’s bed and don’t take up much space. They’re tucked away but always accessible.
If you're looking for a permanently mounted solution to keep your cargo secure, I highly recommend these. Maxzina has knocked it out of the park with these functional, tough, and perfect for my truck!
Ford Maverick Maxzina Ratchet Straps Installed Review 20250601_124039
Ford Maverick Maxzina Ratchet Straps Installed Review 20250604_091338
Ford Maverick Maxzina Ratchet Straps Installed Review 20250604_091334
Ford Maverick Maxzina Ratchet Straps Installed Review 20250601_122041
710-oil-614
Cal
2025 Hybrid AWD Lariat
I want to grab a set but I feel like they have limited use when installed permanently in one location - especially with the cargo management system where you have a range of mounting points. It’d be awesome if they designed a strap for the rails!!
that being said - I get to review stuff on Amazon for free and one of the items recently received we’re the rear shock covers.
Having a hybrid and not wanting to relocate my emergency fuel door release I have no plans to use them.
if someone in central Ohio would like them for free let me know and we can work that out.
GarryB
GarryB
I don't really understand what you mean? Every Maverick truck has set points of hooking any Ratchet Straps. These are great because they're out of the way and it retracts the leftover strap so it's not flying everywhere.
AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
I too am a fan of Maxzina’s self retracting ratchet straps. As designed, the tie downs are fixed in the upper corners at the foot of the bed. I wanted more flexibility in using them to assist in securing oversized cargo. My intent was to mod the tie downs incorporating a fabricated bracket permitting them to be positioned and secured anywhere along the rails as with the divider. This required drilling and machining a metal construction tie. The accompanying photo show what I accomplished.
I actually use two pairs in my Maerick’s bed. One pair rides the side rails. A second pair is attached to the upper corners of Mabett’s sliding bed divider. These correspond to additional anchor points I added to Maxzina's front bed wall Molle panel.
Ford Maverick Maxzina Ratchet Straps Installed Review IMG_2100
Ford Maverick Maxzina Ratchet Straps Installed Review IMG_2102
Ford Maverick Maxzina Ratchet Straps Installed Review IMG_2103
Ford Maverick Maxzina Ratchet Straps Installed Review IMG_2104
Ford Maverick Maxzina Ratchet Straps Installed Review IMG_2110
Ford Maverick Maxzina Ratchet Straps Installed Review IMG_2155
The Real Maverick
Jack
How would it work though pulling at an angle? Imagine I have a potted tree or something dead center of the bed. How would it work pulling at a diagonal?
710-oil-614
Cal
For trucks equipped with the cargo management system you have rails on the inside of the bed that you can adjust the mounting location and attach your ratchet strap from there.
Since I have these it makes it easier to select the perfect tie down location instead of having to only use the corners or the bed.
GarryB
GarryB
I'm glad you asked!
I put the hook in the corner and retracted it then tightened it and it spooled in perfectly. The metal portion of the ratchet is designed on a slight angle so it came back with ease. I was really surprised that it didn't get stuck at all.
I hope that helps!
GarryB
GarryB
I believe the Lariat has the rail Cargo Rails which would work with what you're looking for but these are definitely a cheaper alternative to the Lariat 😊...
GarryB
GarryB
That's a great idea!
Thanks for sharing, best Ratchet Straps I've ever used.
GarryB
GarryB
I also love the Maxzina Bed divider so that's on my list at some point.... 😊
710-oil-614
Cal
Rails are available on any trim level (standard on Lariat) for $225.
While that is more than the Maxzina ratchet straps they provide different functionality.
I’d like to combine both😉
GarryB
GarryB
I wish I knew they were available!
Maxzina sells them too and I have realized that the after market accessories I've installed in my Mav are better and cheaper than what Ford sells... I'll be trying out the Maxzina ones for sure. And of course I'll post a review of them too...
Good luck with your purchase neighbour!
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
AbnRgr
Athens, AL
While I have a numberof Maxzina products incorporated in my build, I recommend them all. When it comes to bed dividers, I recommend Mabett’s. Without any modificaation it slides along the length of the rails. With a simple mod, the divider can be moved, flipped, and secured without tools.. It offer versatility.
