Not true. Seems you're the one who doesn't understand.What people don't understand is: technically every new F-150, F-250, F-350 also has "electric only" miles when coasting. Just the computer does not keep track. Fuel is completely cut off, thus in those big trucks they are driving on battery only too, just no regen. And some have auto stop / idle stop too.
The ICE in a hybrid can be disconnected from the wheels via the eCVT. On electric drive only, only the electric motors are connected to the wheels. The high voltage battery can power both the drive motors for propulsion, and every single accessory in the vehicle, including the AC compressor, without using a drop of gas until the battery is depleted, or you ask for more power than the HVB can supply.
In a traditional/EB ICE with fuel shutoff capabilities, the ICE remains connected to the wheels at all times when not in neutral. All of the moving parts within the ICE are still moving, providing drag on the powertrain. Basically means that you're not simply coasting, nor are you getting regenerative braking. The engine does need to keep spinning, though, because all of the accessories in an ICE vehicle (e.g. climate, alternator) are powered by the rotation of the ICE.
The only time an ICE in a non-hybrid will stop while the vehicle is still running is when the vehicle is stopped and auto start/stop engages. In that mode, you're not in some electric only driving mode; only your 12V accessories are running. Meaning even your AC compressor, powered by the ICE, isn't working. All you get is the fans running to blow the last of the pre-chilled air out at you; then the ICE has to kick back on to maintain temperature.
An F-150 with auto start/stop and deceleration fuel shutoff is not comparable to driving a hybrid, such as a full hybrid electric vehicle (FHEV) F-150 PowerBoost, let alone a Maverick Hybrid.
