Mabett side lights - how to wire?
Don's Maverick XL
Donald
MISHAWAKA
2023 Toyota Corolla hatchback SE
Anyone know how to wire the passenger side for the mabett side light I did drivers side according to instructions and it work fine then I went to wire passenger side and instructions said yellow wire from light goes to blue withe green strip but there is no blue with green strip there are only 3 wires coming out of turn signal blue with white strip thick black wire and small blue wire. So I hooked to the blue and white because it's in the same place as other side but still did not work so can anyone help or do I have a bad light
Leftnut
Todd
2024 xlt
You might try bench testing to check operation, and by doing both sides you would be confirming the test procedure.
Don's Maverick XL
Donald
MISHAWAKA
Thanks but I think the passenger side light is defective
CurtisB
2023 Maverick XLT Hybrid
The instructions that come with the set for the passenger side are wrong. I don't have these installed but have read in here somewhere that the passenger side needs to be spliced into the thicker wire.
Biagio
Biagio
Oakville
2023 Ford maverick
It's a defective product, I've had to return mine. Driver side had a missing led in the strip and passenger side had major condensation. No communication from mabbet for any help either.
dc73pdsgt
Tucson, AZ
try the thicker wire as was previously stated for the passenger side... that's what I had to do with mine because when I wired mine up according to the directions the passenger side was staying on all the time. when I moved it to the thicker wire it worked fine.
Don's Maverick XL
Donald
MISHAWAKA
Just sent back. going with fake carbon fiber ones for $26.00. to many bad reviews on the lights so no lights for me
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
I don’t have a light on the right side right now, I started out with the thicker wire and the light stayed on.
uga
SE USA
2026 Ford Maverick XLT
Try this and let us know if it works:
Passenger side wire info:
Yellow side marker wire - blue with white stripe (thin wire) - brown connector
Red side marker wire - blue with green stripe (thick wire) - black connector
Don's Maverick XL
Donald
MISHAWAKA
Thanks but to late already sent back for refund mostly because there is no way to get ahold of the Mabett company for any help so to me that's a red flag so I am replacing mine with fake carbon fiber design. If another company comes up with something like this and actually has a customer Service number I might try again.
uga
SE USA
From the Amazon ad 5-11-24: "The package includes a plug-and-play wiring harness."
The lights are great, however, it is strange that a company would continue to claim they are plug and play, they are NOT. Also, intructions for wiring are NOT correct for all models and years. Finally, the connectors/taps should be better quality or better yet, lets have a plug and play connector!
