- First Name
- Tony
- May 4, 2025
- Raleigh, NC
- 2025 Maverick XLT
- Engine
- 2.5L Hybrid
Took me about 90 minutes to put them on. As much as I wanted to stand back and say “those look great”, “those look right” is the more appropriate reaction. The lines are complete now.
A couple of lessons learned along the way:
- Once you've got the flare lined up with the holes (a small screwdriver inserted into the holes makes this easy), use some painters tape to hold it in place. This islike an extra set of hands.
- Insert the clips first (top to bottom) before sticking any of the adhesive (despite what the instructions say). You don't want to be repositioning adhesive tape to accomodate a clip that was a little off.
- Expose a little of the adhesive as the instructions say, but be sure to do it only from one end. This will allow you to stick it down in a single smooth swipe, ensuring perfect adhesion and really good fit.
- A small flat blade screwdriver is very helpful for popping the center part of the clips. It's dark in those wheel wells, park in the sunlight and/or use a light to help find the spot to pop out those clips.
- The included clips are great but are shorter than the originals. Use whichever fits and holds the tightest.
Comparing Mabett's flares to others
This is the second set of flares I'd ordered. The first set came in three pieces per wheel and didn't line up worth a $%^&*. Not worth the $30 savings over the Mabett version.
I also considered a few options from Ford Accessories including the $670 Air Designs (which are identical to the Mabetts) and $550 Husky (didn't care for the fake bolts and overall bulky design. great if you are going to put big-ass tires on I suppose, but that's not something I plan to do). Neither is worth 4-5 times the price of the Mabetts.
Looking at a 2026 XLT at my local dealer with similar flares installed (presumably the Air Designs judging from the line item on the sticker), the fit was noticably worse with wide gaps where the exterior color shows through between the bottoms of the flare and black trim across the bottom of the body. This is likely and installation issue (only $210 at your local Ford dealer),
Lesson learned: take your time can get it all lineup before adhering them (#2 above). The clips really help here.
