You must work for FordIt's like 1 in 25,000 units.
Yep, mine did a sort of rumble strip shudder during braking a month ago. I glanced down and saw the ICE hadn't warmed up much and assumed it was a rough coordination event between the engine, and eCVT. Hasn't done it since. Mine is a 9/23 build.
On a related noted; I have noticed the ICE can have a quite a lumpy "cold high idle" when the PCM decides to start it, to charge the HV battery. Also causes some surging while warming up--feels like someone has tapped the truck from behind. Also, if the ICE hasn't been running and up to temp, there can be a hesitation from a stop, from when you stab the throttle and the ICE shows up for work.
Anyone with a 23’ that was built toward the end of the production for the year, having the shudder on decel when it goes from ice to electric? I believe mine was built late August 23’. I saw a Tsb, but it seems it was for the earlierbuilds
