Lane assist disabled
bpcooper14
'08 Nissan Frontier
Hybrid XL with 360.
Just installed switches to add cruise to my XL this morning. It was my first foray into forscan and all went (mostly) smooth. I was not able to get the abs values to write, kept getting an error. The switches both work fine, cruise works as it should, and my limited testing seems that the cruise is not affecting my mpg as far as I can tell.
Interestingly enough, however, the lane assist now does not seem to work. It is greyed out on the display as if it is "active" when I cross either lane line, I am not getting the vibrating steering wheel alerting me.
After work, I plan on going back, resetting all of the values back to stock in forscan, and reprogramming the switches. I can't think of anywhere I would have changed a value that would have disabled this. Has anyone seen anything similar? I'll update with any info once I have it.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hybrid XL with 360.
Hi there! Can you send us a PM with your VIN and Ford dealership information? I’d be happy to look into this Maverick lane assist concern on my end.
Maverick2022XL
name
hinterlands
Your lane assist problem is most likely due to putting in the wrong steering wheel code in the SCCM.
This is correct code for cruise control with the stock buttons and the lane keep assist left turn stalk installed.
SCCM - 724-02-01
1258 6820 3050
XXX-*XXX-XXXX
That particular value is for lane keep assist. The on value is different for different switch combos chances are yours is still set to A which is the on value for switches without cruise control.
Maverick2022XL
name
hinterlands
The ABS issue is most likely you not using a new enough version of forscan.
This is one of the newest betas that should write your ABS module.
https://forscan.org/download/FORScanSetup2.3.47.test20220228.exe
You may not see an immediate decrease in gas mileage on a short run with CC on without the ABS set correctly but you will see it over a longer haul and excessive braking to maintain speed using CC without it set right.
bpcooper14
'08 Nissan Frontier
I'll take a look into this later tonight or in the morning. Thanks for the newest forscan link too!
bpcooper14
'08 Nissan Frontier
Those values all seemed to take. My original SCCM values that I had changed to were 1258 4820 3030. I'll update later if I see any issues. The stalk now seems to function properly after a short test drive.
The only thing that I have a question about now is, while driving, on the left cluster with the battery/engine/tachometer (whatever you want to call it), the word READY is constantly illuminated. I can't remember if it was there before while I was driving (I've only had it since Thursday and was out of town all day Sat/Sun so did not drive it). No error codes were being displayed in forscan.
EDIT: Just watched through a few videos and it appears that everything is working as it should (Saw the Ready displayed on a few displays)
This group is amazing! Thanks again everyone!
