Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets
thev8man
***** LOTS OF PHOTOS *****
I just installed Morimoto 2Bangers WIDE beam HXB's on my Tremor using JJC-LLC.COM Brackets.
https://jjc-llc.com/products/2023-f...76590&pr_ref_pid=6943258542126&pr_seq=uniform
https://www.morimotohid.com/2Banger-LED-Pods-HXB-Wide-Beam?quantity=1
I have few phases of instruction and photos and more to come.
The install is 4 out of 5 wrenches 🔧. It's not a fast one but well worth it. There wasn't a pre-cut pattern to sketch out the lights, so I had to do some drawing on the inside of the bumper before cutting.
I did pre-fit the lights on the truck before tracing the 2banger lights on the inside of my bumper. I like the JJC-LLC.COM brackets because they have a lot of adjustment that allow for proper alignment and modifications.
The Morimoto 2Bangers WIDE beam HXB's have a great pattern for foglights there are SAE certified and I'm glad I went with the HXB's. These lights are incredible. I installed the Diode Dynamics foglight kit on my Hybrid and they looked great off and were good when turned on or in park light mode, but these 2banger lights are amazing 👏🏽 when Illuminated.
The Diode Dynamics kit is designed for an easy and quick installation. This is a well thoughtout set of "Bracket's" that allows your imagination to run wild. You can use Diode Dynamics, Morimoto, Baja Designs, KC daylighters, or a no name internet special set of lights.
You will have to cut your bumper. You will need to remove your bumper. There are clips and screws in the fender wells, skid plate, and on the top of the grille that need to be removed to take off the bumper. There is a little trick you have to do with two clips that are on the grille assembly. You will have to push the two clips that are on top of your radiator to have the grille release. There are also a set of special clips on the bumper that go into the fender. The clip has tabs on both sides that need to be pushed in to allow the bumper to come off.
The is no cover piece that comes with the Brackets alone. JJC-LLC.COM has a few options to choose from and if you get a kit with lights from Justin you can get a template and facia cover plates.
JJC-LLC.COM has kits for Hybrids, Regular FWD Ecoboosts and AWDs, as well as for FX4s. Justin also has nefty grille light kits and ditch light kits, and even just ditch light Brackets (which are next on the list).
I attached photos and more photos will come tomorrow.
Booyah 👊🏽 😁 👍🏽 🇺🇸.
Thank You Justin from JJC-LLC.COM
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_121201
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_121154
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_112903
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_112917
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_110536
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_130945
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_124035
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_124044
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_124103
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_124028
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_130933
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_110324
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_131106
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_154358
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_135826
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_110647
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_121413
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_124018
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_193129
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_110315
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_132619
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_212110
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_012610
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_222225
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_012602
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_012541
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_012616
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_193143
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240407_193114
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_012549
thev8man
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇸.
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_144844
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_144758
Ford Maverick Just installed my Morimoto 2Bangers with JJC-LLC.COM Brackets 20240408_144826
Suzukiridr14
Frank
Sarasota Florida
Booyah 👊🏽 😁 👍🏽 🇺🇸.
Excellent presentation of what is needed, and many pictures how it should look step by step. I don't need this mod myself, but for those who would like it, it is the best by far info for them to follow. You should be a shop teacher!
fossil
ernie
ohio
Tremor gets some love!
thev8man
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇸
We'll indo appreciate you and your kind words. Thank you
thev8man
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇸
Thank you Justin. I truly appreciate you and your work. I sent you a few emails and photos.
thev8man
thev8man
Booyah 👊🏽 😁 👍🏽 🇺🇸
Thank you so much.
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
Booyah 👊🏽 😁 👍🏽 🇺🇸.
I tried going to
and was blocked. Can you try and let people know that it is a good website?
The other website worked just fine.
quikandskinny
UT
2024 Maverick Lariat Tremor
