Interior Lights - WT !
boxster03
michael
santa fe NM
2023 Maverick XL Area 51
So tonight I used my key fob to open the truck from a far and the interior lights didn't come - they have come on up until tonight
They didn't even come on when I opened any of the doors
If I start the truck and open a door they will come on for a short period of time but that is it
Something has changed
'23 XL (Not a Hybird model) and it has never been to the dealer for any recall work or even an oil change - only 1,700 miles
Any ideas ?
Ozarkbeard
You likely need to charge your battery.
monkey302
VA, USA
Focus RS, Maverick Lariat Hybrid
Make sure you didn’t pop the dome light switch on the headliner to the off setting. I’ve accidently don’t that on every car I’ve owned and been confused for a minute or two.
CurtisB
2023 Maverick XLT Hybrid
You must be new to the forum. This is common.
boxster03
michael
santa fe NM
It is my daily driven battery causing my truck to go into deep sleep mode - so say bye bye to this problematic vehicle - trading it off on a new Nissan Frontier
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
You're about to have the deep sleep problem, as the 12V battery is not charging correctly. Its probably either the bad connection problem in the power distribution box under the hood, or the cracked 300A fuse issue.
