Installed bushwacker flares
Stock411
HI
2022 Ford Maverick XLT Hybrid
Overall I like the look on the truck, they fill the groves on the fender Nicely as it seemed like it belonged there.
install was a pain in the butt, it required additional set of hands to apply pressure to get the holes to line up. Ive heard someone drilled bigger holes but this wasn’t needed. Additionally the plastic clips were even harder to press in with the flare on top. Needless to say it was worth it since there’s no drilling into the fender.
here are some pictures *disclaimer I actually don’t have FX4 (it’s a hybrid).
Ford Maverick Installed bushwacker flares D85BC299-7D22-47B0-95CE-6C9BF73510B0
Ford Maverick Installed bushwacker flares 87CA7890-251E-448B-A31D-4763091ED1DD
F-050 Maverick
Fredericksburg VA
2022 Mavericki
I've also installed the Bushwacker flares. I agree that they look like they really belong there and that when I see other Mavericks on the road without them I think the truck looks naked. My install did require that I drill out the holes on the flare to accept the clips, but the rest was exactly as the directions said. I have the Shadow Black and this blends in and complements the other matte finishes just fine. Pics to follow once the sun comes back out.
Djhartman712
DJ
New Jersey
How did you remove the clips?
Are the clips all that is holding it on or are there screws under those clips?
Stock411
HI
All plastic clips, there’s a metal brace but it’s held in with plastic clips. The metal brace then holds a single screw for the flares.
Just used a plastic pry tool or door trim removal tool.
Djhartman712
DJ
New Jersey
Do you have any pics of the before and after?
Timpositive
Maryland
I bought the Bushwacker fender flares and I'm installing them. I've got two ~6" long parts with a clip in the middle. No instructions - I'm not sure if these are for the front or back in addition to not knowing which side is which (they are different) and where the heck they go. Any advice would be appreciated!
Ford Maverick Installed bushwacker flares IMG_7034 (1)
gwalton1234
Geoff
St. Louis
2007 Saturn Aura
OK, I answered my own question (by calling Bushwacker tech support). The brackets go on the front. Attached is the installation pdf for front (20139-02_r0) and rear (20142-02_r0). :cool:
Thanks for posting this.
JsnMrd
2016 Honda Civic Touring
Will mpg suffer if I put this on my hybrid?
