Is a skid plate available for a 2024 Hybrid. I am looking primarily to make oil changes easier
I installed the Rival skid plate when I did my first oil change. Should be doing the next change in a few months so I cannot speak about the change with the plate.Is a skid plate available for a 2024 Hybrid. I am looking primarily to make oil changes easier
I did something similar on my 22, and used 1/4 turn catches to hold the “doors” closed. This worked well until I replaced the openings with 3d printed panels. Here’s a post on it:I used metal snips to make the hole by the drain plug big enough to drain oil through. Then I located the oil filter and cut a door into the felt liner underneath it. The door is hinged at the front by not cutting that side and it binds against the other edges to keep itself shut.
I run amsoil so I only do annual oil changes, but this has allowed me to never have pulled the whole liner down since new.
