Hybrid owners: for those that have off-roaded how did it go?
BoskoPColtrane
Bosko
I am still going to take it where trucks can go. Plenty of 2wd truck going off roading, naturally, they are less capable in mud, sand, and deeper holes so I will avoid those trails/fire roads
Yes. A lot of two wheel trucks but from what I’ve been told the hybrid suspension is a lot lighter than the suspension for the regular engine. Could be wrong.
atomguy245
Doug
CT
My Hybrid successfully hopped the curb up onto my yard. No issues.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
BoskoPColtrane
Bosko
Hardening2753
Hardening2753
Ford Maverick Hybrid
I think the front is the same as EB but the rear is different
Distracto
Central Florida
2023 Maverick XLT Hybrid
I have installed falken wildpeak trail tires as a compromise between all season tires and really heavy duty all terrain tires.
I recommend this even if you just regularly traverse gravel roads as it makes the truck much more capable and comfortable on that kind of terrain.
I’ve gone to forest service roads and have had no issues getting stuck. I’ve gone up really steep dirt/rock driveways and even with wheel slip never lose momentum.
For difficult stuff I recommend you leave the truck in normal and disable traction control.
If you are going a little faster rally type stuff (please try not to do this), I recommend traction control on and use slippery mode.
If you are crawling slowly up or downhill use L mode. It’s not a real low range mode but I like that it keeps me from gaining too much momentum.
Do NOT go over obstacles that could strike the bottom of the truck. The ground clearance is not great and damage could result.
The angles/break over of the truck are poor too. You will scrape the front or rear if you try to climb too steep suddenly.
If your definition of off-roading is basically bad roads, dirt paths, or fields then you will do just fine.
If it is rock crawling, mud, or anything requiring articulation you will probably not be fine. You’ll always need front traction to make it anywhere.
I know trail conditions change from day to day, but keeping it general, have you had any experience in sugar sand or on the beach in the hybrid? How'd it go?
inthecabin
Andy
2021 Ranger Lariat FX4
Sugar sand aired up don’t stop, keep plowing found out the hard way
dearbulls
Dan
GA
Look at my profile pic. Off roaded with a 900 lbs ATV in the back.
It handles my hunting club travel pretty well. the stock XL tires are crap handling mud holes even with factory slippery mode. But I've now activated the deep mud and sand mode on the hybrid. I only use it to go highway to and from my hunting land, and I'll use the ATV there. So the factory tires and extra mode should help. Haven't tried it yet.
Worst case I'll get some good AT on my AWD. I think some AT would also help with hybrid but its going to kill your MPG. Oh, BTW, if you are towing or hauling, the EB would probably be better on both power and efficiency. The Hybrid is definitely not designed for hauling at free way speed. it's better off just driving around town by itself.
