Hybrid bedliner for hybrid? Success!
Hockeyfish11
Ed
2024 Maverick
Hemmed and hawed about ridding my truck of slippery drop in floor mat but keeping the four sides intact. Factory soft bed mat slightly oversized thus not a great fit. Removed side tie-downs and floor tie downs and was able to remove floor piece. Laid in soft mat and was able to get it under both sides. A carpentry flat bar and a few good palm swats got it under the front piece.
Ford Maverick Hybrid bedliner for hybrid? Success! IMG_1737
Milton Jeff
Jeff
Milton, Ontario, Canada
2024 HPR XLT Lux
Where did you get that floor mat? Is it ordered fromFord parts? Cost?
Hockeyfish11
Ed
2024 Maverick
Yes. Bed mat a Ford product
Flight Test
DFW
Corvettes
SKU: NZ6Z99112A15B
Maverick 2022-2024 Black Bed Mat
$170.00
or redeem up to 34,000 Points
Accessories.Ford.com
Milton Jeff
Jeff
2024 HPR XLT Lux
Thank you..
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Looks like a good solution to protect the sides and not have things slide around without an expensive spay in liner.
oneinch
Stanton
SE Pennsylvania
'22 Maverick Lariat
Looks like you made a DualLiner which isn't available for the Maverick. Nice! Plastic sides, rubber floor.
Benilla
Edmonton
I did the same w/ a Muslogy mat b/c that mat has a lip on all sides.. makes containing the garbage juice from jump runs much easier haha.
mepot101
Orlando, Fl
2024 Ford Maverick
Will that mat fit with the floor section still in place?
Would be nice if the floor was not so slick.
Or any other mats that would fit on top of the factory drop in liner floor?
Flight Test
DFW
Corvettes
I have the DIBL and used this mat last week to haul 1420 lbs. of small Arizona cobble. The mat is a bit tight at the edges due to the extra thickness of the side panels. I did not mind because the mat was just a temporary use for this situation.
Hockeyfish11
Ed
2024 Maverick
No. It will “wrinkle” from being too tight
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Professional spray in isn't as expensive as some people think. Well worth every nickel- I've spilled gas and oil on the tailgate (thanks Hurrican Helene chainsaw duties!) and it just sprays off. We've slammed stuff around in the back for over a year without a scratch.
Hockeyfish11
Ed
2024 Maverick
Not a good fit. Wrinkles or it needs to be trimmed
Cleek
Central Texas
24 Maverick XL
