How to display hybrid power screen
Tony
NC
2024 Maverick Lariat hybrid
I have seen a Maverick power train screen which displayed whether the electric motor or the ICE was engaged.
I have searched through all the menus but I can't get back to that screen. I also looked in the owners manual but no luck.
Any help? Thanks
Electric Vehicle Information
Power Flow
Ford Maverick How to display hybrid power screen {filename}
The power flow information for your hybrid vehicle is available through the home screen or under Apps.
Vehicle Operational States
Power flows to or from the front and rear wheels depending on operational state and drive conditions.
  • Idling: The vehicle is running and in park (P). The engine and/or the high voltage battery are on.
  • Electric Driving: The vehicle is running and in drive (D) or neutral (N). The high voltage battery provides power to the wheels.
  • Hybrid Driving: The vehicle is running and in drive (D) or neutral (N). The engine and the high voltage battery provide power to the wheels.
  • Regenerative Braking: The vehicle is running in drive (D) and is slowing down. Power captured by the regenerative braking system is sent back to the high voltage battery.
Engine On Due To
The following conditions help to explain why the engine is on, and what you can do to allow all electric operation.
  • Drive Power: The engine is on due to accelerator pedal pressure or speed control activation. Reduce pressure on the accelerator pedal or switch off the speed control to return to full electric mode.
  • High Speed: The engine is on because the vehicle speed exceeds the level for full electric operation. Reduce the speed to return to electric operation.
  • Heater Setting: The engine is on because of the heater setting. Reduce or turn off the heater setting to return to electric operation.
  • Neutral Gear: The engine is on because the vehicle is in neutral (N). Shift out of neutral gear to return to electric operation.
  • Engine Cold: The engine is on because it is cold. The vehicle returns to electric operation once the engine is sufficiently warm.
  • Battery Charging: The engine is on to charge the high-voltage battery. The vehicle returns to electric operation once the battery is charged.
  • Low Gear: The engine is on because the vehicle is in low gear. Shift out of low gear to return to electric operation.
  • Normal Operation: The engine is on to optimize vehicle operation. The vehicle returns to electric operation when possible.
  • Engine Braking Active: The engine is on to provide increased powertrain braking. This can occur when you turn on the grade assist feature, when speed control is on or when driving with your foot off the accelerator pedal. Turning off grade assist or speed control may allow the vehicle to return to electric operation.
  • Battery Temperature: The engine is on due to high or low high-voltage battery temperature. This is a normal operating condition. The vehicle returns to electric operation when possible.
  • Drive Mode: The engine is on due to the drive mode selection. Select an appropriate drive mode for electric only operation.
Escapologist
Niagara Region, ON
Is it the one where you have the drive mode main screen up and select it on there?
MaverickMark
2023 Maverick Lariat
Any help? Thanks
If you have a lariat, select apps, then power flow on your center screen. That will take you there.
My Lariat doesn't have that option? My Escape PHEV does though.
I don't think you get it in the 25MY.
Manual doesn't mention it like it does pre-25MY's.
Letsride
bruce
east tx
2025 Maverick
Any help? Thanks
It's on the small screen next to radio. Swipe down until it shows up. Three different options - connected phone, travel data and ICE/electric
Art Vandelay
New York
2023 Hybrid Lariat Alto Blue
I have that screen on my 2023 Lariat however, the option is not available when I'm connected to Android Auto. Even if I go back to the main Ford screen the Power Flow option is missing when connected to AA.
chris5038
Ft Myers, Fl
2024 Ford Maverick Lariat
Any help? Thanks
LSchicago
Lloyd
IL
Any help? Thanks
If it is a 25, it can display on the far right section of the screen. You may need to scroll down to it.
Tony
NC
Yes, that's it! Thanks. And as Art Vandelay mentioned, it is not available when Android Auto is running.
