How might I power rear seat heated covers?
NatePabrant
Nate
24 Tremor
I grabbed these heated seat cushions right before a mountain trip for the rear seats. Only to find out they couldn't be plugged in the back, I thought there was a car lighter socket and 400w outlet in the rear. Whoops.
Ford Maverick How might I power rear seat heated covers? IMG_8116
Then I scoured Amazon for some kind of adapter, that could convert the two prong outlet into the male car lighter and found this:
It's quite bulky and means I'd have to leave it under the seat in storage.
Ford Maverick How might I power rear seat heated covers? 71PTDUp3lNL._AC_SL1500_
I eventually grabbed a car light extension: Which I guess the extra cable also has to be stored under the seat, but I really don't want it running to the front car lighter.
Ford Maverick How might I power rear seat heated covers? 71jFjtFJtrL._AC_SL1500_
Are there any other similarly priced options
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
  • Wire the seats directly to the fuse box and install a switch?
  • Cut the plug off and wire your extension cord to the fuse box?
  • Install an after market 12v plug in the back wired to the fuse box.
The adapter you found is kind of a counter intuitive. Going from 12 VDC to 100 VAC then back to 12VDC when 12VDC is available all though out the vehicle.
GPSMan
Many
PSSSSSST....
You can also run cables under the center console.
SHHHHHH...... don't tell anyone.
RoyalTeaDee
North Carolina, USA
Dodge Caliber R/T
you could try something like this.
Cellet AC to DC 12V Output Converter. AC/DC Power 110V- 120V AC to 12V DC Car Cigarette Lighter Power Converter. AC to DC Female Adapter (Not for Air-pump, Compressor, Vacuum cleaner) https://a.co/d/3oxfGwU
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
This ^^^
To the op
do you have a link to those covers
NatePabrant
NatePabrant
Nate
24 Tremor
My XL has a 12v power point in the rear of the console. I don't know the amperage, though.
Oh, that’s probably why I thought that I had that also. In my one week of shopping there was so much information to learn across all the models. Not all of us know every nuance of the truck we are getting especially when we are unfamiliar with the make and model, the irony is I have the upgraded luxury package and therefore cannot just plug in heated seats 😂
GPSMan
Many
There's your solution. For the most refined stock look, get an XL.
Problem solved. Glad we could help.
Vols44
Missouri
2018 Edge
My 22' XLT has a rear console 12v outlet. The owner's manual recommends a 15 amp, 180 watt limit since the fuse is rated at those thresholds.
I bought a Wagan heated seat cushion since I don't have a luxury package. It consumes 40 watts with 4 amps of DC current.
