Which one would fit my 2023 XLT? I've included photos.
I have the same without a power mirror as well. Which would I have to get?
Thanks for jumping in and helping out, really appreciate it.No. The GPS included with the Mangoal dash cam does not integrate with the Ford infotainment system or instrument cluster.
Its GPS is used to:
- Record the vehicle's location, speed, heading, and time along with the video.
- Display your route and location when reviewing footage in the Mangoal app or compatible video player.
It does not:
- Display a live navigation map on the factory SYNC screen.
- Add navigation to vehicles that don't already have it.
- Send GPS data to the Ford infotainment system.
The dash cam operates independently of the vehicle's display—it records GPS metadata for your videos but doesn't interact with the factory navigation system.
One of the best features is how unobtrusive it is. It blends in seamlessly with the factory interior, and you almost forget it's there until you need to review the footage.
Hey Cancun,2024 ford maverick Lariat Tremor
Wich one should I order
Plug and play preferred
For a 2026 Lobo with the Homelink auto-dimming mirror, you’re good to goNeed a recommendations for front and rear cam for 26 Lobe High package with Homelink auto dim mirror?
Just to clarify, that link is actually a Fitcamx unit, not ours—though the OEM-style housings look pretty similar from the outside.I bought a front camera from Amazon and no way is this thing 4k. Is the difference the sensor? I don’t think the one I have has the Sony sensor? https://a.co/d/00qvIF7z
Link to 2023 Maverick cam pleaseJust to clarify, that link is actually a Fitcamx unit, not ours—though the OEM-style housings look pretty similar from the outside.
You're spot on about the sensor, though. That specific model uses a GC4653 sensor and upscales native 4MP to "4K" in software, which is why the footage looks soft.
That's actually why we stick with Sony STARVIS sensors across our Mangoal lineup (along with metal heat sinks). Native resolution and dynamic range make a massive difference over software tricks, especially at night.![]()
Here you go: https://mangoal.com/collections/all/2022-2024-ford-maverick-esr3530524Link to 2023 Maverick cam please
I don’t see pictures of the rear camera?
Mike's feedback was incredibly helpful, and we've been making improvements based on what we learned from early Maverick owners.midnight43026 (Mike) is very knowledgeable about this dashcam. In fact he has a valuable
video that I hope he posts, curious if Mangoal has solved this before I purchase.
Thanks, Mike !
Here’s what the rear camera looks like. It’s a small cylinder unit that mounts directly to the inside rear glass (and rotates 360° so you can adjust the angle).I don’t see pictures of the rear camera?
Hey, model A fits your 2023 Maverick XLT.Which one would fit my 2023 XLT? I've included photos.
Awesome thanks!For a 2026 Lobo with the Homelink auto-dimming mirror, you’re good to go
These are the Maverick-specific options that fit:
https://mangoal.com/collections/all/2025-2026-ford-maverick-esr8148696
Front only or front + rear, depending on how much coverage you want.
The gps is not needed, but you can just install it right under the mirror trim. There is a small void there that looks like it's for a gps antenna.Will the unit function properly if you elect not to install the GPS antenna?
