Headunit not detecting USB flashdrive
Jamsandolina
Samuel
2024 Ford Maverick XL
New to the group.
Hello, I just purchased a 2024 xl fwd maverick about 10 days ago. It only has 350 miles on it. I listen to my music from a USB flashdrive plugged into the USB port under the a/c controls. My problem started a day or two after I brought the truck home. The head unit will stop reading the USB flashdrive and disconnect from it and resort to playing the FM radio. It has done it about 5 times already and seems to be getting worse on the length of time it takes the head unit to re-recognise the USB flashdrive. Today it did it twice on me and took forever to play again. I attempted to to do any updates on the head unit but there were none to be done. Has this happened to anyone else and if so how did you resolve it. Thanks
OleFordGuy
Maybe try the head unit reboot process and see if that helps. Any change the flash drive got corrupted or anything. Maybe try reformatting it and add your songs back on it. Not sure if its picky on the format as fat32 or the other options. No idea if updates are available for non sync 3 units. Good luck
VinnyH
Vince
Doerun, Ga
2025 Maverick Lariat Hybrid 4K BAP, 2024 Maverick Lariat Hybrid BAP
My 2023 XLT would do this a few times a week. Those XL/XLT Ford radios are pretty glitchy.
Graboid
Al
Pacific Northwest
2020 Sprinter 4x4, 2009 Honda Element, 2004 Audi A
Yeah same here. It seems that the audio system spins the "wheel of random nonsense" every time it starts up just to find annoying ways to mess with me. Am not impressed.
colinl
Colin
ICT
Yes, and the OP might not know what it is.
To reboot the infotainment, hold down power (push center of volume knob) and fast forward / skip forward until the screen goes black.
VinnyH
Vince
Doerun, Ga
As usual, good advice Colin. Using your sound system-related posts (as well as others on here) I was able to install an HS10 in my Lariat hybrid. Thank you!
Jamsandolina
Jamsandolina
Samuel
I've tried the reboot process...still happens. I checked and I'm pretty sure it has the latest update seeing my truck was built last month (manufacture date 2/24). My flashdrive is an onn 2.0 so maybe that's the culprit. I ordered a Samsung 3.1 flashdrive. I'm gonna have a friend that knows alot more than me about downloading stuff put my music on the new flashdrive. If it still does it after that I'm heading on down to the dealer so they can check it out. I briefly spoke to a service advisor there about my issue so they are aware of it. I want to thank everyone for the advice and help.
VinnyH
Vince
Doerun, Ga
Good luck- I hope you can get it sorted out! That used to drive me crazy in my XLT. Time will tell if the Lariat Sync 3 system in my new truck is any better.
CurtisB
2023 Maverick XLT Hybrid
Plug the adapter in the other USB port and see if it still happens. Some here have found one of the ports is bad.
Jamsandolina
Jamsandolina
Samuel
The other one is a type C plug in if I'm correct. My flashdrive can only be plug into a USB port. If that's what your asking?
colinl
Colin
ICT
so get a cable with USB A on one end and USB C on the other, or an adapter from C to A.
not difficult. don't buy a cheap generic Chinese cable, they're often problematic.
Jamsandolina
Jamsandolina
Samuel
Didn't think about doing that. I'll stop at wally world today and pick one up to try that out. Thanks
OleFordGuy
