Got a turn signal recall on my 23XLEBA51
scotty
pompano berach fl
dodge caravan
Normally, when a bulb burns out or goes bad in a car, when you throw the lever for the turn signal to work, the indicator on the dashboard will blink real fast, letting you know that a bulb is out. Apparently, this has NOT been happening with the Maverick. Thus, if you turn on your signal, you are assuming the person behind you sees your rear light flashing and if the bulb is out, without the update, the dash indicator will NOT flash rapidly. The update fixes the issue.
Ok, now I understand. right the fast blink has always indicated me that very thing
06Warrior
Person
19' HD Road Glide, 22’ Sporster S
Dealership did the recall Tuesday when they replaced the defective axles.
