- First Name
- Eric
- Mar 21, 2025
- Hampton, VA
- 2024 Maverick
- Engine
- 2.5L Hybrid
I was annoyed by a few things with my Maverick. 1)Lack of power points that were accessory, not constant. 2)Crawling into the passenger footwell to get access to 12V power. 3) Futzing around with those tiny fuses.
I back stabbed a connector to the BCM pin 35 which is a constant signal from the key ACC/RUN position and then ziptied the tap wire to the factory wire. Maybe not super reliable but easier than re-pinning and I HATE vampire taps.
The latch for the connector is a bit finicky. In the middle of the latch handle, the middle part presses in to unlock the handle and then the handle swing left to right and the connector slides right out. During re-install, you do not use the handle as much. Just press the connector and the handle will swing right to left until fully seated, then move the handle right to left to engage the lock.
One weird thing that I ran into along the way. I built most of it detached from the truck inside the house. For a power source I used one of those tiny 12V battery that are typically found in key fob alarm buttons. The battery would drive the LEDs fine. It would drive the relay fine. It would not drive both. I started to doubt that I knew how to build a basic relay circuit. After checking all the wiring, I saw that it would flash the LED strip briefly then the strip would go out. It was also hard to hear/feel the relay trip as there was a noticeable jolt in my fingers when the I was touching or disconnecting the leads. I do not recall any feeling when closing the circuit but breaking it was very noticeable.
The hub does not do data. I tried. The hub is USB 3.0 high speed and wants to do data but the truck does not. The one I selected did include a 120AC -> 12V transformer and I got lucky. The barrel power connector that came with the LED strip was the same size as the USB hub.
