If they're the 8" wide 55 offset wheels they actually won't stick out, they'll actually have less poke by about 5mm (The face of the wheel will be further in 5mm than stock wheels) and the inside edge of the wheel will also be closer to the inside strut by about an inch.They'll bolt on, but the offset is off, so the wheels will stick out.
https://www.tirerack.com/wheels/tech/techpage.jsp
Translated, they will not look good on the Mav. Or, you can get a wheel spacer to make the offset look correct. Also will depend heavily on tire choice. Something SO many people get wrong is just choosing a wheel and throwing it on, and for quality looks it just isn't that simpleIf they're the 8" wide 55 offset wheels they actually won't stick out, they'll actually have less poke by about 5mm (The face of the wheel will be further in 5mm than stock wheels) and the inside edge of the wheel will also be closer to the inside strut by about an inch.
