Forscan write blocked on 2025 XLT Hybrid
scott112
Scott
2025 XLT Hybrid
Hello all,
I`m using Forscan V2.3.68 with Windows 11 and the Vgate vLinker FS USB adapter. When I try to write to the IPC module as built or ez module I keep getting writing blocked and access denied errors. I have successfully written to the BCM module for DRL to turn signals. Anyone else have this issue or a idea why this happens?
Ford Maverick Forscan write blocked on 2025 XLT Hybrid 20251121_111504
scott112
Scott
2025 XLT Hybrid
Never mind. Forscan sent me 2.3.69 Beta to try.
850_maverick
2025 Maverick Hybrid
I am having the same issue with the IPC module on my 2025 XLT Hybrid. Did the beta version help? I am using the trial license now, but I'd gladly buy a license if that helped you and if that's what I need for them to give me the beta to try. Thx in advance for any advice.
scott112
Scott
2025 XLT Hybrid
The Beta version lets you rewrite the IPC module. I used the disable all for seatbelt menu and chimes and it works perfect.
850_maverick
I purchased a license and joined the forum, but I only see the link for the 2.4.20 beta version. What caused you to use the 2.3.69 beta and how did you get it? I am currently using the 2.3.68 release and I don't want to make a mistake by jumping too far ahead to the 2.4.20 beta if that's not as stable or could be a problem. Thanks in advance again!
scott112
Scott
2025 XLT Hybrid
I emailed forscan tech support with my model (2025 XLT Hybrid) and issue, They sent me the that version. Before that none of the other versions would let me write to the IPC module.
https://forscan.org/download/FORScanSetup2.3.69.test20251125.exe
Make sure you back up your Module first and take pics beforehand.
Phil1349
US
2025 Lariat
StarBug
2025 Hybrid Lariat
D.W.
D
FL
2025 FORD MAVERICK XLT
Anyone know if "FORScan 2.3.69" will work with Windows 10?
BlueSpec1
Gene
