Forscan question
oltexboots1
T.
Houston, Tx
2026 Maverick Tremor
Ok.... I've encountered rumors of forscan being able to override the auto reset back to "normal" mode with each key cycle on the 2026 tremor. I'd be very interested in that information. Also, the ability to change the color of the maverick on the display to blue :) .
mjtavares70
Marc
Syracuse, NY
2025 Ford Maverick Hybrid awd lariat
Forscan really isn't that hard and as others have said, the setup isn't terrible. I've shut off the annoying seatbelt menu, the TPMS warning for my snow tires (will be turning that back on with my summer tires), target start of charge to 95% and the 12v accessories from 4500 seconds to 120 seconds (I still think this is part of the battery issues everyone is having!). I am planning on doing the all up/all down with the fob soon and a few other minor things.
TremoringDan
Dan
Morrisville, NY
2026 Maverick Tremor, 2026 Maverick Lobo
Marc, we're almost neighbors - small world.
How were you able to remove the seatbelt menu?
mjtavares70
Marc
Syracuse, NY
There are a few settings you change based on the forscan spreadsheet. Fairly easy. Just got the windows up/down with the fob working last night.
TremoringDan
Dan
Morrisville, NY
Could you be a little more specific like, which module? I have the 2026 spreadsheet and I don't seem to see where I can disable the screen.
mjtavares70
Marc
Syracuse, NY
I think this was one of the more straightforward ones. It’s all in the same module, IPC as built. Just change the 5 settings based on the below.
Ford Maverick Forscan question 1778585134682-gs
Ford Maverick Forscan question 1778585267763-u
Ford Maverick Forscan question 1778585345524-9
TremoringDan
Dan
Morrisville, NY
Hi Marc, Thanks for the reply. I must have a different spreadsheet, mine is no where near as simple looking as what you posted.
I am literally person #1 in North America that added adaptive cruise to a Ford Ranger so I have a strong grasp on using Forscan.
mjtavares70
Marc
Syracuse, NY
This is the one I’ve been using. It’s pretty basic but helpful. I know there’s a much more detailed version, just haven’t needed to get into that depth yet.
Forscan 2022-2024 Ford Maverick - Google Drive
TremoringDan
Dan
Morrisville, NY
Do you have a direct link? The picture you posted crams into the frame and is mostly unusable without heavy scrolling side to side.
Weird that I am unable to grab it or download it.
Hopefully my questions will assist others in the future.
Thanks
Edit, I think I found it. I have a 2026 so the spreadsheet I have almost has TOO much info.
I have the 2022-2024 file which looks quite similar to the one you posted.
Vluc
Vince
Western Pennsylvania
2025 Maverick Lariat
Now what gets changed when this is posted? This change relates to these numbers but is it something that is seen only when in forscan?
Ford Maverick Forscan question 1779027713337-1g
