Forscan Double Honk
jjplus5
2018 Ram Power Wagon
First, I apologize if this has already been posted, but I have been literally searching for hours now trying to find this info and do not see it anywhere. I have a ELM327 now with Forscan downloaded and am trying to turn off the double honk function in my truck. Everything is working and I backed up the BCM as-built module. My issue is I do not know which code is for the double honk. I have the most recent Forscan download and it only shows the codes such as 726-10-01 and not the description of the code such as Double Honk and a Enable/Disable function. I checked the web as well and see how to do this on a F-150, but our Mavs have different codes. Does anyone know how to change the code itself or change the display to the description instead of a code? I have a Ecoboost Lariat FX4.
thanks for any help,
ShadowBlack XL440
Robert
Northern Ohio
Try contacting this person on the double honk.
https://www.mavericktruckclub.com/forum/threads/has-anyone-used-forscan-yet.4250/post-206059
jjplus5
I have it figured out now. I only had to select the Bdycm config line instead of the Bdycm as-built line. Difference between easy and advanced. It all works now and thanks.
UnkleFunk
Louisville
2022 Ford Maverick XL 2.0L
It works? You got rid of double honk?? Can you explain?
