Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid
troynm
New Mexico
2022 Maverick Lariat hybrid, Velocity Blue
I recently completed installing Sirius/XM radio in my new truck. I thought I would document it for those wanting to install it in their Maverick. The mounting bracket is unique and uses the dash cubby next to the center screen.
The first thing I ordered was a set of tools to remove different dash and console panels.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647212298103
After ordering the Sirius radio, FM adapter, and Bluetooth dock. I started by ordering Pro.Fit bracket number FO-73-05-L for the Ford F350 Super Duty series of trucks. I wasn't sure if it would work and realized the long arm was probably not long enough to reach the front of the cubby. https://pro-fit-intl.com/products/2...duty-legend-mount?_pos=2&_sid=cb6761615&_ss=r
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid FO-73-05-L Mount
As expected it was not long enough. I solved the problem by using (2) 1x2 inch spacers cut to length and glued together to fit inside the cubby. I removed the top cubby behind the screen to figure out where to put the bolts for the spacers and run power, FM adapter wire, and antenna wire. The top half of the cubby is free and clear for bolts but the bottom half is restricted. I drilled holes in the wood spacers for #8 2 inch bolts and then using the wood spacers as a template drilled holes in the back of the cubby keeping the wood spacers as far left in the cubby as possible. This is important to keep the bracket from rubbing or rattling against the side of the cubby. I drilled a hole in the left side of and towards the top of the cubby large enough to fit the 3 wires I needed to feed in.
I painted the spacers black and drilled holes for the bracket screws again keeping them as far left as I could go then bolted the blocks to the back of the cubby. I mounted the bracket the spacers. The photo below was a test fit of everything before I painted the spacers.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid IMG_1476
I used a clothes hanger as a fish tape to bring the wires up from the passenger side to the top cubby and ran them into the previously drilled hole in the side of the cubby.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid IMG_1474
I got a little bit ahead of myself and did not cover installing the antenna. I selected an area on the drivers side roof and ran the wire down along and behind the windshield. I then routed the wire down into the engine compartment and found an oblong rubber grommet on the drivers side in the firewall. I cut and X in the grommet large enough to get the antenna wire and its jack thru the firewall to the passenger compartment. Then I routed the wire over to the passenger side by removing the side covers on the console.
I use an automatic car wash with brushes that can be kind of brutal. I did not believe that the magnet on the antenna would be strong enough to hold it in place. After thinking about it a few days I used silicone glue to fix it to the roof. I was worried about wind or the strong blowers in the car wash may suck the wire out from under the ledge of the windshield so I applied a light coating of silicone glue to the wire and stuffed it in there. I believe it will stay in place and allow me to pull it out if I want to remove it for any reason. Please, no comments on the car wash. I know it's not good for the finish but I'm 69 and have some physical issues. I'm not going to wash and dry the truck manually.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid IMG_1455
Now I have an antenna and my power, antenna and FM adapter wires run over to the passenger side and a clean install of the unit.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid IMG_1484
For power I purchased a power adapter as I did not want to use the cigarette lighter type plug that comes with the XM radio. You can order it from Amazon from here.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647211320070
I ordered the XM FM adapter and adapter cables to use as my audio input. You can use a Bluetooth dock for the XM radio but you can only use one Bluetooth item at a time in the Maverick and would preclude using my phone at the same time. Yes, you can get an XM app for your phone and use Apple or Android Car Play and not bother with all of this at all. The problem is in New Mexico and Colorado if you are not on the interstate or close to a decent size town you will have no cellular. You would need unlimited data as well. I did order the XM Bluetooth dock but for the above reasons decided not to use it. The problem with the FM adapter is if you live in a large city you may have difficulty finding an area on the FM dial to give you interference free reception.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647211844843
You also need the adapter cables so the FM adapter can plug into your Maverick radio.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647211964699
You need to remove the front console cover to get to the antenna jacks on your radio. The FMDA25 plugs into the gray antenna jack on your Maverick radio and the Maverick antenna plugs into the FM adapter. I forgot to take a photo of the console and radio but you can see a photo at this link https://www.mavericktruckclub.com/f...y-inputs-in-the-back-of-the-radio.5638/page-3. That link is from another gentleman on the Maverick forum who installed another style of XM radio.
Last is getting power to the radio. You need to purchase a micro-2 fuse extender. I found one at my local auto parts store but you can get them from Amazon here.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647213114110
You need to be sure to install this correctly following the directions. It will plug into your fuse panel two ways. One way is not correct. I plugged it into fuse 3 in the panel in the passenger side fuse panel. This is for the auto-dimming mirror and there was a fuse in there although I do not have the auto dimming option in my truck. This circuit is hot when the car is running and cold when the engine is off.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647213439324
For a ground point I attached it to a screw under the right console panel.
Ford Maverick Installing Sirius/XM Onyx EZR Radio in Lariat Hybrid 1647213404637
I ran all the wires up into the top cubby panel and inserted them into the hole in the front cubby I mentioned earlier. Excess wire I kept down in the passenger compartment, coiled them up and stuff and wire tied them behind the right console panel.
It works great and it's a tidy installation. If I missed anything I will try to add it later.
DJF
OR
Jeep
Pretty impressive DIY project. :)
Chris_G
NOVA
C-6 Corvette
I'm confused, SiriusXM is included with the Lariat.
Dave_in_PA
Eastern PA
2017 F-150
Also, the Sirius/XM app works on all trim levels. Since I'm constantly connected to Android auto, I rarely actually use the Sirius/XM tuner built in.
Regardless, I love the engineering and ingenuity.
Chris_G
NOVA
C-6 Corvette
troynm
troynm
New Mexico
The app on your phone is great if you have a cellular signal! It can be pretty sparse out here in the American west especially New Mexico, the state I live in.
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
You are right. We have terrible cell service here in rural East Texas. So much so, I don't even have a smart phone. Used to use an iPhone back in my business days, but then I travelled a lot and needed the connection to my office. Now, a flip phone is all that I need since I can't use CarPlay here in rural East Texas.
Chris_G
NOVA
C-6 Corvette
Isn't the shark fin antenna on the Maverick for satellite?
uh50
Howard
www.hchaney.com
As far as I know, the shark fin antenna on the XL does not include the SiriusXM function. At least when I installed my SiriusXM Commander Touch there was not a SiriusXM satellite antenna cable at the ACM unit. :cool:
troynm
troynm
New Mexico
The antenna is probably satellite equipped but you would have to access it thru the headliner although my Tacoma had one and even an antenna lead that came down to behind the drivers kick panel. Made it easy to install XM.
Chris_G
NOVA
C-6 Corvette
Thanks!
Chris_G
NOVA
C-6 Corvette
It would be nice if the maverick has the cable.
Dave_in_PA
Eastern PA
2017 F-150
When I travel In north central pa, I get spotty signals and sometimes lose my connection. It's a shame Ford didn't make it a simple upgrade to get sirius for people in rural areas like yourself.
I am curious if you can upgrade the Maverick using a kit from 4D Tech. Although they're pretty expensive, I used this company to upgrade my dad's sync to give him navigation a couple years ago because my parents do a lot of traveling.
