Automan21
Mel
CT
‘23 XLT Eco AWD 4K Tow
Do you think it would still have enough clearance with this wheel and tire set up, if I installed the Goodwin Racing Lowering Springs?
I think so, you’re not going super low. I’m also looking at the Goodwin set up with 245/50/19 offset of 45.
I’m no suspension specialist but I’m guessing I’ll be fine too.
EONR24
EONR24
Swag
United States
2024 Ford Maverick XL
How wide are your 19 inch wheels? 8.5?
colinl
Colin
ICT
Those arches and the inward positioning of those wheels has the effect of making it all look smaller. Spacers to bring it out a little would improve the look. (My opinion, doesn't mean it's correct)
It's definitely the backspacing, yes. The 235/60-18 Defender is a pretty meaty tire.
Ford Maverick Focus ST wheels installed! 1715795944706-da
the problem with spacers is that wide ones have included studs so that you don't have to buy longer studs, and this adds weight. you might be able to get away with 5mm spacers without changing lug nuts or studs, but there's some risk in 5mm less thread engagement, and 5mm wouldn't even be cosmetically noticed.
EONR24
EONR24
Swag
United States
Yes I would like to avoid using spacers. I have done it on previous vehicles but I really would like to avoid it. I think adding Goodwin lowering springs will really help the look but im concerned about the inner clearance because its already tight and with added negative camber, I do not want any rubbing.
shadow76
bob
TX
F150, Ranger
While I like the rims, am concerned about the inner clearance.
Still awaiting production of Cragar SS rims.
EONR24
EONR24
Swag
United States
me too. It does not rub but that clearance is tight!
