Flexbed Mods to the XL Maverick
Bry@n
Bryan
Central NJ
23 Maverick XL, F150, Bronco
Purchased the bed side cubby’s, bed upper d-rings and the front bed floor tie downs. Bed cubby’s use a 10mm socket, the d-rings have a T30 screw head. The bed floor tie downs use a t35.
easy install with maybe 35 minutes all in. The rear bed tie downs will be another day since Ford lost the screw I bought.
You will need to remove the rear bed d-rings to install the cubby. It’s just easier. Remove the cover in place first, then the d-ring. Install cubby with door off, then reinstall the d-ring and out the cubby door on. The bed tie downs I just sent with a 3/8 impact. Could’ve threaded the holes but the screws will self thread the hole for you.
Ford Maverick Flexbed Mods to the XL Maverick 8DB3BC2F-EEF0-43E4-A399-DA99DE72C175
Ford Maverick Flexbed Mods to the XL Maverick 2A835992-47C4-4D5D-BA7D-A6FCF93DA3DB
Ford Maverick Flexbed Mods to the XL Maverick 7E962F58-6A7E-4B55-909C-86031BF955BF
Ford Maverick Flexbed Mods to the XL Maverick C41AF448-20A2-4579-A4E6-25A51D691921
Ford Maverick Flexbed Mods to the XL Maverick 6FB0C523-86F4-4A15-8C8C-8A5C658B5A0F
Ford Maverick Flexbed Mods to the XL Maverick A6BA3D96-4BF2-48A6-887A-CB354DB70876
Ford Maverick Flexbed Mods to the XL Maverick 85FCE9D7-39F2-40D6-8626-987F171FA326
EastFlorida
'23 Maverick XLT
I plan to add the cubby to the driver's side on my XLT. Thanks for the part number!
I already added a 12V receptacle and dual USB ports where the pull outs are on both sides.
Ford Maverick Flexbed Mods to the XL Maverick IMG_20230212_095519131
Ford Maverick Flexbed Mods to the XL Maverick IMG_20230212_095548331
JamesC
LI, NY
06 Mustang GT
Excellent, can you provide links or part numbers please?
EastFlorida
'23 Maverick XLT
jewc75
Hopefully you live or park in safe areas. Some asshat stole one of my cubbies so now i have them installed with security torx bolts.
Mc_Flier
Area 51 Maverick Hybrid, Street Glide Special
Driving an XL, flexing the Snap-On. 🤣😉
Bry@n
Bry@n
Bryan
Central NJ
I wouldn’t be judging what I can afford by the Maverick. I have a F150, Bronco and a few Suoerduties also. :). Just didn’t see the value of going to XLT or Lariat in the Maverick platform for my needs.
TedTX
Ted
San Antonio TX
You beat me too this. Had a friend 3D print the plates but the wire adapter had too small spade plugs to attach correctly. Used same amazon part as cheap parts. So still a work in progress for me.
Mc_Flier
Nop
Nope. Joking about the XL. Judging the pile of Snap-On. 👍🏾
TedTX
Ted
San Antonio TX
@EastFlorida: the button on the usb plug question? Does the usb stay on when 12v power returns on if left on, or do you have to press usb on each cycle of 12v power. Want to charge a usb rechargeable lamp whenever truck is running.
EastFlorida
'23 Maverick XLT
The button can turn off the USB - simple on/off button. Power stays on with the truck off until it shuts down on it's own. I saw a post about how long it stays powered, but I don't recall how long.
jojotarantino
Peoria, AZ
2024 Maverick Hybrid XL
jojotarantino
Peoria, AZ
I just got an XL and didn't realize the differences in the tie downs from the higher trims. I'd like to at least add the upper tie downs near the end of the bed, but the holes aren't threaded right? I am not super handy so I don't know the best way to do this. I've read you need to thread with a tap, but then I've also read self-tapping bolts work? what's the best way?
Bry@n
Bry@n
Bryan
Central NJ
I think I listed the stuff above or at least it’s on the site. The bolts do self tap. Just use the correct Torx bit and send it.
jojotarantino
Peoria, AZ
Thanks I appreciate the reply. I went back and looked at everything again. The only thing I'm not quite sure is which screws to buy for the upper tie down ring as I may only do those. I was going to do the floor bed D rings also, but $66 each currently seems a bit much.
