Electrical leads
GAP
Lancaster, PA
Honda Pilot
I see the XLT has “two pre-wired standard 12v electrical leads“. Does that mean the wiring for a rear outlet is installed to the bed?
paneubert
Seattle
Yes. 12v though. So you would need an inverter if you were trying to step up to 120v.
  • Like
Reactions: GAP
crunchie_frog
Todd
Johnson City, TN
2023 XLT 2.0 4K, 1999 & 2000 5.0 AWD Mountaineers
Does anyone know if these power leads have power with ignition off or they only have power with the ignition on? Thanks,
GAP
Lancaster, PA
Honda Pilot
if I have a Jackery that runs off 12v can I use that as my converter?
paneubert
Seattle
I would think so, since the Jackery would be doing all the effort to output the 120v from its internal battery. It would probably drain faster than it would recharge though. I would check to see what the max draw for the 12v input is on the Jackery to ensure you aren't going to be trying to pull too much amperage from the Maverick when the Jackery is trying to charge itself.
I see one reference online that says: Alternator Charge Rate (12V Input) - Jackery: ~8A (@12V)
Internet tells me "The all new Ford Maverick comes with not just one but two e-DIY 12-volt power sources in the truck bed, both are good for 20 amps."
