Eibach camber bolt kit
colinl
Colin
ICT
The rear suspension on a FWD is basically a solid axle and most solid rear axle vehicles have little to none alignment adjustments from my experience.
I'm with you.
A twist-beam rear axle is not really independent. *technically* you can have a little bit of independent wheel action, and Ford chooses to state that the FWD Mavericks do have independent rear suspension. :unsure:
good pics and info about the FWD maverick suspension here:
https://www.autoblog.com/2021/12/01/ford-maverick-fuel-economy-suspension-deep-dive/
Jamsandolina
Jamsandolina
Samuel
2024 Ford Maverick XL
I just had my '24 XLT Hybrid aligned after I swapped the springs to the Eibach kit.
If you would like I can Google lens the spec sheet and send it to you?
Yes please and thank you
