Driver side daytime running light won't shut off
Larryhd1
Larry
Bloomfield Ny
2018 ford echo sport
Oscarcat
Eric
Encinitas California
Nice CPR color! As for your issue, why don't you try disconnecting the battery for about 5 minutes, then reconnect. See if that "resets" things.
Have you done any electrical mods?
Bob The Builder
Butch
Vermont
These trucks are rolling computers. As stated above, reset the rolling computer.
Oscarcat
Eric
Also set the headlight knob to the”0” icon in case you use the “A” , auto on, like many of us.
Oscarcat
Eric
…when you reconnect the battery, start the truck and verify both left and right DRL’s illuminate. Check for a bad bulb that is out.
Larryhd1
Larryhd1
Larry
Bloomfield Ny
Only have 300 miles not unhooking anything lol
Like when?
After you've turned it off, and gotten out of truck - it's still on until you get in and turn knob to off, or even then never turns off and battery drains?
While driving, you have the option to disable them - and it's still on only that side?
Get into the settings and enable the DRL so it matches the action being performed.
Shut truck off.
Start again and disable setting.
Truck off then on.
Still a problem for 1 side only?
300 miles - back to dealer.
Larryhd1
Larryhd1
Larry
Bloomfield Ny
Bingo back to the dealer thanks can't even disable it
Carlitos_92
I could swear there was a post from OP about Mabett marker lights? Were those already installed, or just on a future wish list?
