Driver side door handle.
Dhines1749
Donny
Forks Washington
I received my Ford maverick lariat one month ago, after a week the doorhandle which is supposed to unlock when the key is close to it stop working. I took it back to the Ford dealer who told me they would have to replace the door handle but couldn’t tell me when the park with a ride.
clavicus
My typo interpreter detects “when the part will arrive”.
Dang that’s a bummer but glad it’s a minor part that can be replaced easy once it arrives. The intelligent access is pretty slick, when it works.
The Weatherman
Dean
KY
There had been comments about a wire disconnect happening in doors earlier on.
Also, its not just proximity, you do have to place your fingered inside the handle. I bet you already knew that thou, right?
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
Did you try this?
Push menu go to locks, intelligent locking an deactivate, then reactivate.
Dad
I had the same happen. I solved it by accessing the Intelligent Access mode from the instrument display and disabling it and re-enabling it. Haven't had a recurring problem. Apologies if perhaps you tried that.
Rickrollin'
Todd
Vancouver, WA
2022 Ford Maverick Hybrid
Did you try this?
Thank you for this. I've had my Maverick since May, just shy of 6k miles and drivers door access stopped working about a week ago. Was just about to call the dealership and decided to check online first. Tried this and it worked. Thank you again!!
