Diode Dynamics Hitchmount LED Brake/Reverse Light
Ottocycle
Baja Georgia
23' RS6 Avant, 14' CTS-V Wagon, 87' BMW 535is
  • Thread starter
  • Banned
  • #1
Just wanted to post that the Diode Dynamics Hitchmount LED Brake/Reverse light for the 2021 F150 also is plug and play for the Maverick. Only thing I don't like is it sticks out past the hitch but im going to fix that shortly. Yes, it's pricey but it's a nice piece.
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230508_172217
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230508_170816
How to disconnect the plug; you slide the Grey piece back then you can press down on it.
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230508_171228
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230508_171225
does it require the truck to have the 7-pin connector harness or will it work if equipped with the 4-pin connector harness?
Ottocycle
Baja Georgia
  • Thread starter
  • Banned
  • #3
I'm not sure as mine has the 7 pin; can you check the back side of your connector under the bumper? It's about a 1.125" diameter plug. Just poke you phone under there and take a picture to save your body. I'd be surprised if the 4 pin and 7 pin would share the same plug on the backside. Ford can save pennies per vehicle buy using a cheaper connector, although retooling/rewire costs hmm...
bguen
Billy
2010 Honda Pilot, 2018 Honda Accord
I was looking in the Diode Dynamic hitch mount light, but the dealer where I was going to buy the light suggested that the Backup Camera would be white washed with the light directly under it.
That's why I went with two 1" Ridge Cube lights and wired them to the reverse tail lights.
Here are some pics...
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light Reverse Light
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light Left Reverse Light
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light Right Reverse Light
Ottocycle
Baja Georgia
  • Thread starter
  • Banned
  • #5
Looks good; I do not have an issue with it washing out. I will post some pictures of it at night, with reverse and the backup screen. I also have a putco led bar, still no wash out even with that.
Ottocycle
Baja Georgia
  • Thread starter
  • Banned
  • #6
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230603_213114
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230603_213024
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230603_213337
Ford Maverick Diode Dynamics Hitchmount LED Brake/Reverse Light 20230603_213151
Lasfit LEDs all around plus putco led bar.
Cancunbadlands
Cancun
Cancun
@Richardkratz here
