Do you know the advantage of using #3 instead of the #1,#2 slot ?Yes. I believe that is correct.
I had not given that a thought. GoodWhen running the power, if you don't pull the A pillar trim off at least at the top, you run the risk of the power wires laying over the top of the air bag. That is not a good route for the power wires. You want the wires to be between the metal A pillar and the air bag so it does not interfere with the bag deployment if someone hits your Maverick.
No. It was one of the first fuse slots identified as an accessory based (not powered full time). So I used it.Do you know the advantage of using #3 instead of the #1,#2 slot ?
DO you know if #1,#2 is the same ? It says "spare" only.No. It was one of the first fuse slots identified as an accessory based (not powered full time). So I used it.
