Daily Driving in Lobo Mode
Cherokee
Op, you lucky boy,
Drive it like you stole it and keep us updated.
Personally I think pussy footing around with an Eco boost is just wrong.
Vroom vroom.
colinl
Colin
ICT
#BTW I always drive my 2023 BS BL in sport mode
I'm missing it in my 2024 Lariat Tremor, wich I drive in Normal mode
You can definitely add sport mode with forscan, or you could try sand mode as it gets an aggressive throttle map like sport mode.
Cancunbadlands
Cancun
Cancun
You can definitely add sport mode with discreet forscan, or you could try sand mode as it gets an aggressive throttle map like sport mode.
I'll do it! TY
yldman56
OFallon, Missouri
2025 Lariat w/blackout package 2.0 AWD
Ford recommends I change my oil every 10,000 miles & only use Lobo Mode at the track.
I know the effects of a 10,000 mile OCI, but what are the effects of driving in Lobo Mode off the track? I do not plan on taking my Lobo to the track. But my daily driving has twisty turnys & a world class canyon road 10mins away.
Pros:
One - The much tighter steering is a wonderful daily driving feature. I paid extra for that & only turns on in Lobo Mode
Two - Auto Start/Stop is disabled, although also true in my previous default Sport Mode.
Three - The torque vectoring RDU is also only activated in Lobo Mode. I also paid extra for that - and it improves cornering so much better than my vaunted strut tower brace.
Four - AI engine noise is a bit louder & a bit more helpful in determining shift points when paddle shifting (I drive in “M”).
Five - My mpg’s are at 22mpg instead of 21mpg in Sport Mode.
Cons:
One - Engine revs higher. In Sport Mode, 4th gear is a good steady state high gear for my daily driving. Lobo revs higher in 4th & I have to shift to 5th sometimes.
Two - When slowing to a stop, Lobo Mode does not automatically downshift as smooth as Sport Mode. I do not downshift while coming to a stop - I let computer do that for me.
Three - Braking dynamics are different too. I think they are better - but need to acclimate myself.
Any other pros & cons I’m missing? There might be ABS and Traction Control changes I need to consider. Also think the suspension changes - although I’m not sure about that….
Edit - no change in suspension per MavStangVa input
Only thing I see would be more wear on the RDU in LOBO mode. But remember with today’s vehicles all that information goes to ford, so if you have a warranty claim, it might affect that.
Chops
Chops
Lobo
Thanks - I plan to change the RDU fluid at half the recommended interval. Same with PTU.
My “platinum” extended warranty states they cover the RDU + PTU….as long as I avoid Track use.
r0tax
CO
2025 Lobo 402A VB
Lobo mode is fine in Manual mode, but pretty obnoxious in Auto mode.
It WAY over revs in Auto and really tries to 'hold' certain gears/RPMS way too long. Which is probably fine for a Noob who doesn't know how to manage gears, at an autocross track for the first time. But not super for daily driving.
But, with Manual mode it feels great when grabbing gears (up and down) in Lobo mode. And will mostly stay put in the gear you choose.
I still think its annoying having it Auto downshift to 1st when I stop; when in Manual mode.
2nd Gear is plenty Low enough to pull away from a stop light/sign. And the 1st and 2nd gear are so redundant that they could replace 2nd with a properly gapped gear ratio.
Basically 1 and 2 feel way too close to me. And the gap from 2 to 3 is too large.
I have to really pay attention when downshifting from 3 to 2...and often don't.
It seems like somethings a bit funny or off.. Sorta like they just removed a gear out of an 8 speed, and retuned the shifting to skip a gear or something.......
Wish there was a 6MT, and it wouldn't matter.
Chops
Chops
Lobo
Agree - I only drive Lobo mode in manual.
I actually like prefer the manual paddles more than a manual transmission gasp. I prefer to have the “computer” operate the “clutch pedal”. It does a very good job. No stalls & no money shifts:)
Escapologist
Niagara Region, ON
Ummm, you know it's a turbo motor right?? Should be making power to redline and you don't want to shift down early and end up out of boost in what is a RACE MODE.
Just seeming a rather silly objection to a race mode acting like a race mode.
Chops
Chops
Lobo
Um, you know that Lobo does not have a RACE MODE? :)
It shares the same turbo, engine, and transmission (minus a gear) as all Mavericks.
The “Lobo Mode” emphasizes the HANDLING upgrades. Tighter short ratio steering in Lobo Mode. Stiffened suspension & lowered center of gravity that is tuned to the Lobo Mode’s torque vectoring program. Brakes from the Focus ST.
When Ford let the automotive press test drive Lobo Mode - they did not line them up to race lol. They let them drive through cones & corners alone - solo & separated. Rarely getting above 35mph or above 3rd gear.
I find the Lobo Mode’s handling enhancements wonderful - but I’m not racing:)
Escapologist
Niagara Region, ON
You make it sound like finding a parking spot in a large lot. So nobody had a clock running or nothing?
(BTW had multiple parallel thoughts collide when I said "down" when most would have said up, was thinking down a ratio number, up a gear, down in revs and down came out.)
But anyway, whatever the competition is, cones, drifting, nobody wants random gear changes in the middle of hard corner or to be off the power curve coming out of it, so it's doing what it should be doing, for special offroad purposes, which I lump together as race, even if it's for fun and the only thing racing is your pulse.
Also Ford will not be doing what you want to do for public road driving, if the change breaks traction it will have clowns going off asswards into trees.
Torque vectoring is also a bit pointless/ineffective if there's very little torque to vector, so why the hell would you want to drive in the no torque zone and just pretend like it makes a difference.
Maverick123
Waiting
The shift logic in my MDX is perfect : when you're in Drive (D), you can shift manually via the paddles, but it'll auto-upshift to avoid the rev limiter and downshift to avoid lugging the engine.
When you put the shifter in Sport mode (S), you can let it shift automatically and the programming is damn near perfect : it'll auto-shift at redline to maximize acceleration, and hold on to gears while cornering to avoid upsetting the chassis. It always seems to be in the right gear for fun driving.
Here's the kicker: when the shifter's in Sport mode, as soon as you shift manually via the paddles the truck will hold the gears you select NO MATTER WHAT. You can bounce off the rev limiter as long as you want, it will never auto-shift (unless you come to a complete stop). Sport mode + selecting any gear with the paddles essentially puts you in full manual mode.
I don't understand why Ford wouldn't do similar logic for the Lobo mode?
Chops
Chops
Lobo
Plenty of torque to vector - particularly at daily driving cornering speeds. Although you are obviously smarter than AI that states:
“Yes, the torque vectoring in the 2025 Ford Maverick Lobo does assist with low-speed cornering. The Maverick Lobo is equipped with a twin-clutch rear drive unit that enables torque vectoring, which is active in Lobo Drive Mode (intended for closed-course usage). This system shifts torque to the outer rear wheel during cornering, improving grip, stability, and cornering performance by reducing understeer and helping the vehicle rotate more effectively through turns.
Specifically, torque vectoring enhances low-speed cornering by:
- **Turning In**: Shifting torque to the outer wheel to improve cornering precision.
- **Changing Direction**: Adjusting torque based on the driving situation to enhance agility or stability.
- **Accelerating Out of a Bend**: Directing torque to the outer wheel to minimize understeer during acceleration.
This makes the Maverick Lobo feel more agile and planted, even in tight, low-speed corners, as noted in reviews where testers experienced improved handling on slick surfaces and autocross courses.
pa4ul
Earth but a small spot in texas to be exact
1973 Ford F-100/2025 Maverick Lobo/2015 Mercedes CLA Sport Plus
Try taking a long curve at 80mph and you notice the torque vectoring. The vehicle feels extremely planted though the shift logic is poor at best. My a45 had a dct that was on point for shifting and perhaps that is why i feel a bit spoiled with the delay from click to response.
Maverick123
Waiting
That's what we'd assume, but having experienced the difference first-hand I can vouch that it makes a giant difference, even in normal driving at low speeds.
When it was disabled, my GF (who isn't a car enthusiast at all) immediately noticed the difference in the way the car corners within a few blocks on her commute to work.
It really works
Chops
Chops
Lobo
I don’t have any long 80mph curves in my neck of the woods.
But I have 45mph (35 speed limit) curves on my local low traffic canyon road. The road hugging is incredible compared to all the other vehicles I’ve driven up there!
