Confession time
AutobahnSHO
Will
S.Carolina
Maverick, Miata
If I'm in my own garage I now have pipes that fit on my ratchet as well as my breaker bar...
I was shopping for battery drills a few weeks back and they now have battery drivers too- they're pretty big so it would only work if you had space but I wonder if they couldn't build a 90 degree angled version?.....
Saltwater Cowboys
Josh
ENC
09 Ram 1500, 23 CG XTL Lux, 24 SB Lariat BAP
Anyone active in this thread should also have a can of this in their shop:
https://www.kroil.com/
You're welcome. 🤠
I do. Get it at Napa. But I was working on the boat, which is 20 minutes from my house where my good tools are.
rivermaverick
Fort Mohave AZ
Ford Maverick, Ford Fusion (UK), MEV Sonic7
I literally do that almost every time I work on a car. Alot of times its the only way to get a tool in the place. A straight ratchet or breaker bar may not fit in the area and you have to do that. Can also be combined with stubby wrenches. I also use pipe over wrenches aswell. I have been known to shave down wrench ends, slot boxed end ones, heat and bend wrenches. I also use socket extensions to drive out bolts, and deep sockets with extensions to bend bolts or threaded rod to my whims.
Been there , done all of that. I have quite a collection of bent, ground down and otherwise modified wrenches plus some home made ones - if I ever need to tighten the gearlever collar on an early Lotus Elan I have the tool for it!
Maverickman74
Shane
Maui HI
Why buy a valve stem remover when you can carve one out of a flat head. It's not full finished yet but I have been able to use my brake rotor bender for a few aluminum projects.
