Cleaning the SIBL
Kingfish
Robert
Mount Holly, NC
Maverick XLT
I get that more than a few people are legitimately bothered by imperfections. May I suggest buying or fabricating a bed mat? That way you can take it out when you carry something nasty. Seems crazy to have SIBL and a bed mat - but it would permanently solve this problem. Your bed would always be pristine (at least the floor).
I think fabricating a bed mat is dirt cheap. And the materials are endless. Lots of threads here on the subject.
Yeah, when I get my forever Maverick I won't care. The "imperfections" are just signs that I'm doing cool truck stuff.
For now, I'm just trying to keep this one decent until my '24 gets here.
Good idea on the bed mat!
Kingfish
Robert
Mount Holly, NC
Maverick XLT
If cleaning it won’t work (and I’d be careful of using the brush) you might go another route and use some tire black or even black spray paint to just cover the spots. If you use paint, I would do it lightly and widely so it’s not so obvious.
That's a great idea! I just need it to look good for resale.
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
Try ... and maybe a wire brush.
Dear God. A wire brush? Really? It might work just fine for all I know, but that sounds really harsh.
raymaines
Ray
Tacoma, Washington
I have a bed mat over the SIBL and, if nothing else, it's easier on my knees.
raymaines
Ray
Tacoma, Washington
I'm a pretty clean person, and pride myself on not having water spots... but the bed liner is not one of those places.
I more or less agree, but on a different truck in a different space/time continuum, I bought a scoop of topsoil then didn't empty it out for a week, and the SIBL forever after had a very annoying little white line where the top of the dirt had been. I don't understand the chemical analysis of either topsoil or Line-X, but something wasn't compatible and the "High-Tide" line became a permanent part of my truck bed.
Kingfish
Robert
Mount Holly, NC
Maverick XLT
If read correctly, you have the black spray in bedliner. It is very durable and solvents don't phase it. The exception might be acetone. Sounds like you have paint spots from sliding painted lumber. I soak spots in WD40, then use a stiff brush. If worst comes to terrible, you can use black semi-gloss spray paint to cosmetically repair it when it comes time to sell. But it is a truck and people expect some signs of use. I hauled an old water heater to the recycle yard and used CLR to get the rust off my SIBL. It was not as shiney as the surrounding area but spray paint did the trick. I have also put a piece of plywood down to protect my bed from nails, etc.
Wd40...hadn't thought of that.
Kingfish
Robert
Mount Holly, NC
Maverick XLT
Did you try pressure washing it?
Not yet, but it's on the list after a couple of the other suggestions.
Sounds like a wide spread with lower pressure might do the trick.
Montana
OH NO! Is it still there? You may want to try something like 303. Spray it on a wet bed (giggity) and scrub off with a medium bristle brush. I'm assuming you'd done your fair share of trying already though. Good point though... some earth materials will leave permanent stains when a tarp is not used. If anything, you could just buy some rattle can bed liner and spray a light coat over the top. I'd even try a rubbing alcohol compound in a small area and scrub with that before I resprayed though.
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
Tri-sodium phosphate is my go to for tough construction crap stains.package instructions
Kingfish
Robert
Mount Holly, NC
Maverick XLT
Quick follow up in case anyone else needs to clean spots off of their SIBL.
I tried some Krud Kutter brand cleaner we had left over after cleaning our baseboards.
I gave the spots a heavy spray and let it sit a minute. Then scrubbed with a small, stiff-bristled brush. A quick rinse and it was like new.
