Cigarette Lighter wattage available?
2lbgill
Don
Upper Peninsula MI.
2023 XLTHybrid
Curious on the wattage available if it can supply 400 watts using an inverter.
OrCoaster
Dale
Mid Coast Oregon
81 VW Caddy and 96 Ford Ranger
Being a non smoker I can’t even imagine if there is an ashtray in my truck. I thought all cig lighters got a remake into PowerPoint outlets.
Someone set me straight, I don’t care to get wet running out to the truck to look
XL Hybrid Cactus Gray
United States
2022 Ford Maverick Hybrid XL
Likely blow the fuse.
Watts = Amps x Volts.
I saw in another post, the Maverick has a 20 amp fuse.
For a 12v cigarette lighter or 12v accessory outletMaximum Power Output
Specified fuse amperageWatts = 12v x DC Amps
5 amps60 watts Power Output
10 amps120 watts Power Output
15 amps180 watts Power Output
20 amps240 watts Power Output
It is on a 20 amp fuse so no, unless the inverter would have to be a split phase inverter legs phased to yield 120v. According to previous post OEM inverter appears to be split phase with each of 120 plug (black to green and white to green being 60 volts each. Which most devices will see as 120 volts unless they require pure sine wave). The post if I remember correctly was "inverter weirdness". Try searching if you like. (It's the same as 120/240 in your residence).
There is a smokers package ($70?) which gets an ashtray and actual cigarette lighter which fits into one of the cup holders.
2lbgill
2lbgill
Don
Upper Peninsula MI.
2023 XLTHybrid
I have this inverter this has the cigarette lighter part of the input wiring. I guess that with the 20-amps @ 12v = 240 watts not enough then. Thanks
Depending on inverter! Since you have inverter find an available 40-60 amp power source. The dcdc Hvb converter is capable of sustained 265 amps.
You might check to see where OEM smokers package plugs in?
Ken L
Ken
Simcoe County ON, Canada
11 Kia Soul
Are you talking about the 110v / 400 watt outlet (rear of centre console or in the bed), Optional or included in the lux package, if so it is not connected at all to the 12v receptacle (cigarette lighter), it has its own special system connecting it to the truck.
Ken
OrCoaster
Dale
Mid Coast Oregon
Saved my 70 hard earned dollars for sure!
