- Apr 7, 2022
- Southern California
- White Maverick XLT
- Engine
- 2.5L Hybrid
I have a XLT hybrid, probably one of earlier builds VIN ~5000 with about 7500 miles.
Today the check engine light came on. I've read about the the dead hybrid issue so I have a scan gauge
hooked up, monitoring the 12v voltage. Voltage is charging normally 14+ volts. I read the code
and there was only one code - U3012.
I didn't want to mess with it so I took it to the dealer. By the time I got the dealer, I've restarted 3-4 times
and by the time advisor started the CEL went away. Advisor asked if I received notification on my ford pass app,
sure enough there was one. He was able to look on his system to see the reported fault.
He said the fault is a communication error between modules at start up. Not a system fault so shouldn't affect operation.
Since CEL went off, he advise to just drive it and bring it back if reoccurs.
In other threads about dead hybrid issue, code U3012 was one of the code that was read but there where
many others codes. Not sure if this is precursor to other issues?
Any one experience this?
