Can you lower the rear to level XLT Hybrid?
mepot101
Orlando, Fl
2024 Ford Maverick
I want to level my XLT, but with the cv joint issues, I don't want to change the front while I still have warranty.
Is there a way to lower the rear, and leave the front as is???
Vettereddie
MD
2023 Maverick XLT
I wanted to do the same thing but couldn't find an available solution. Unlike the front end leveling kit to raise it 1" with a spacer block, you would need a new rear spring that gave similar dampening characteristics but at a 1" lower ride height. I ended up just going with the Eibach Pro-Kit (1.5" drop front; 2.5" drop rear), no complaints yet but it does make the ride stiffer and require front end re-alignment after install.
Maybe email Eibach or H & R, there's a chance they have something off the shelf in the right dimensions and spring rate if you don't mind being a guinea pig to try it out. If so, please let us know how it works out. Rear spring swap is actually pretty easy to do compared to the front.
mp24
NE
2022 Maverick XL
Blowtorch on the rear springs until you get the height you want lol
mepot101
mepot101
Orlando, Fl
2024 Ford Maverick
