Can a Lariat owner test this coding?
EONR24
United States
2024 Ford Maverick XL
Ford Maverick Can a Lariat owner test this coding? Screenshot 2024-03-31 at 1.16.37 PM
I am curious if you can enable turn by turn nav in your cluster. I was not able to but I thought maybe lariat owners could because the lariat has SYNC.
UPDATE CONFIRMED TO WORK by @TheShark @ryan2366 on 6.5 inch and 12 inch cluster (lariat only).
Jeff D.
Duluth, MN.
I'm anxiously watching this one hoping someone tries it and it works.
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
I have turn by turn nav in my cluster. I will have a look in this line.
Ford Maverick Can a Lariat owner test this coding? IMG_1988
ryan2366
Ryan
Confirmed although I think I added it through easy mode which changes it in the as built.
Ford Maverick Can a Lariat owner test this coding? Screenshot 2024-03-31 174436
Ford Maverick Can a Lariat owner test this coding? Screenshot 2024-03-31 174038
Nunyabiznus
Al.
Cyber Orange Maverick
I have it it's in the upper left corner
Jeff D.
Duluth, MN.
Ryan, you change your instrument panel out, didn't you? I'm not familiar with your cluster. It certainly doesn't look like mine, atleast. :unsure:
Nunyabiznus, you have the stock Lariat instrument cluster and you can see the turn by turn in the upper left? Or, am I misunderstanding?
Excellent, if so!(y)
ryan2366
Ryan
Swapped with a salvaged 2020 Escape hybrid cluster (Several threads on how to do it).
I had this working on the stock Lariat cluster before I swapped it out.
Jeff D.
Duluth, MN.
Thank you! :)
EONR24
EONR24
United States
Awesome thank you all for the info. great to know this is able to be done through easy mode too!
TheShark
I second that, works on my stock Lariat cluster as well.
