- First Name
- Cal
- Oct 13, 2021
- Ohio...but I'd rather be in Boone.
- 2025 Hybrid AWD Lariat
- Engine
- 2.5L Hybrid
No that's just absurd.Why would it not invalidate warranty? Those parts are going to see much more torque than they would with the factory tune, and they are pretty marginal at the already high torque coming out of the 2.0 engine. If you want more torque than what is already enough to spin the rubber at highway speeds, then you're going to need the heavier HF55 trans from the Transit van and the heavier halfshafts from the Tremor. Oh and don't forget the wider rubber that won't fit in the wheelwell. That's not contrarian, that's a reality check.
I won't need bigger tires and I already have the half shafts - which won't face any additional stress due to increased torque.
8F35 is the known weak point in the Maverick EB drivetrain, no surprises there but it holds just well to the abuse others like @Fast Mavericks and @Dueces have subjected it to - which I won't be doing any of.
You need to research a little before you spout off about reality.
