Biggest tires on stock steel 17 inch rim?
steel rim rider
mike
4058 Mt Terminus Dr
2024 maverick xl
what is the biggest tire I can put on my stock 17 inch rim ? light A/T of course -- my 2024 xl is on order - my other option is leaving stock wheel and tire size and trying the maverick lift any comments - remember I am the steel rim rider
Ford Maverick Biggest tires on stock steel 17 inch rim? IMG_2250
Ford Maverick Biggest tires on stock steel 17 inch rim? IMG_1708
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
245/65/17 is generally accepted as the largest tire you can do on a stock wheel without major issues.
Any bigger than that and the tire weight will likely affect handling, fuel economy, etc.
Some have done 255/65/17 or 245/70/17 with no issues, but I've also seen others claim to have issues (which are likely due to aftermarket rims with different offsets or tires with very aggressive tread.)
hdave
Toronto, Canada
I assume you are a steel rim rider because you like the look, I'd suggest keeping you eyes open on marketplace for those bronco sport badlands aluminum rims that look like steelies, I think they are about 5 lbs lighter so it'll help offset the weight of a bigger tire.
Montana
245/65R17
Considering you are in a hybrid, just got with 235/65R17's and be happy you didn't sacrifice the MPG's. They really did a good job with that tire size and the Wildpeaks on the Tremors. Plenty of tire for what a Maverick is capable of and you truly will not notice a big difference in looks.
I'm running 245's currently in an FX4 and my next tire will be a 235. I've always gone big. 33's on a Tacoma. 33's on an F150. I just don't see the point with these Mavericks, especially the FWD ones. But the "better safe than sorry" rule without too much compromise is 245/65R17 or if you are on 18's, 245/60R18.
hdave
Toronto, Canada
245/65R17
Agreed.
I went with 235/60/18 which is equivalent to 235/65/17 and am glad I didn’t go wider.
IHateSpeedbumps
Nick
Central Texas
Agreed.
I also went with 235/60/18. I like them but I might go a little wider next time. I am waiting to see what 255/55/18 look like.
hdave
Toronto, Canada
For my next one I'm thinking 235/65/18 to fill out the wheel wells better.. But I don't understand gear ratios enough to know if it'll drastically make my drive worse or not.
Ozarkbeard
NW Ark.
'23 XL CP360
You may want to wait until the warranty is out, before doing lifts or larger than OEM tires. There are a number of CV axle failures being reported, mostly on Hybrids. And some dealers are claiming it's caused by customers' aftermarket suspension changes and larger/heavier wheels & tires.
hdave
Toronto, Canada
This is a great point.
generalmgr
Wes
Clarion, PA
2023 Maverick
I agree with 245/65 as the biggest you can safely go on your particular truck. I have an FX4 with 255/65/17 BFG K02 tires... with no rubbing on the liner. That said, as alluded to above, all non-Tremor AWD Mavs have 8.6" ground clearance, all 2wd have 8.3. That little bit, 3/10", may very well be the difference between ok and not ok, because I can tell you my tires are close to being too big, very very close. :)
Montana
Good point. It's a thing no matter how hard some people try to deny it. The added stress from a bigger tire can definitely expedite it and it just gives them a reason to deny the warranty work. Why pay for a CV (or more) if you don't have to? I couldn't even fault a service manager for denying it either. It's a risk we take. No real good reason to deny tires of a factory size though.
