Bed length with tailgate down? Confirmation needed!
Rkbrumbelow
Robert
Cedartown, GA
HCH2, Hybrid XLT on order
King ranchero already settled the discussion, but the width of the door at a 45 degree angle times 2 absolutely does add to the overall length. The door doesn't fold and retract under the bed!
So a 20.3 inch tailgate added to a 54.4 inch bed gives you 78.25?
Are you into a new maths?
Terrenceyao
Terrence
Cactus grey 2022 hybrid maverick XLT lux
3.85” gap between the bottom edge of the tailgate to the end of the bed is very reasonable. Why does that sound absurd to you?
Terrenceyao
Terrence
Not kidding at all. Granted this pic isn’t the Maverick, but in general, the hinge is not like a piano hinge the has a minimal gap when opened and closed. When closed, the gap between the plastic bed liner is probably only 1”. When open, you can see the gap grows.
Ford Maverick Bed length with tailgate down? Confirmation needed! 374EEB4B-C134-4AEA-A4B9-68876A5010F1
bobtheslob
Scottsdale AZ
14 Escape Titanium, 17 Flex Base
Still looks to be about an inch. I've owned a lot of P/U's in my 71 years, can never remember a gap that was 3-4 inches unless the tailgate was over loaded and bowed like my buddies 65 F100 tailgate after loading a small asphalt roller...
There's the gap itself but also the portion of the tailgate that is below the bed floor when closed that is also added to the length when opened.
From the above example this whole area becomes exposed and is now usable.
Ford Maverick Bed length with tailgate down? Confirmation needed! tailgat
Terrenceyao
Terrence
Here’s how I see it. I’m pretty sure “X” will be bigger than 1“ and closer to 3 or more.
Ford Maverick Bed length with tailgate down? Confirmation needed! 4F90884D-ACC0-4371-9A3E-43A383694FF4
Rkbrumbelow
Robert
Cedartown, GA
The problem is Ford published a different number. Trust who you want, I am trusting the guys who designed it and have the CAD files as well as the actual physical pieces. And if I am wrong, who is harmed? If I am correct then anyone needing a longer bed is SOL
I'll trust the Ford employee close to the Maverick program who confirmed 78.25". ;)
Rkbrumbelow
Robert
Cedartown, GA
I guess we will see in a month. You build based on your measurements, I will on Ford‘s. Guess which one is guaranteed to fit?
dceggert
Metro Detroit
2017 Fusion, 2019 Ranger, 2024 Maverick ordered
You ruined everything with this sort of logic. The error in a tape measure is so large it can't be trusted! 🤣 😆 🙂
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Is this like the same FORD measurement that for weeks said in their Build&Price website their "bed extender" would not be compatible with their own bed tonneau? Yes, until they corrected their own installation measurement/instructions, and now are backtracking that the "bed extender" will be compatible with their own tonneau cover.
pxpaulx
Minnesota
Wait are you saying you don't believe the exact number from the guy that actually worked. On. The. Truck? Geez, we might need to take away your curmudgeon card! 🤣
Rkbrumbelow
Robert
Cedartown, GA
I am saying we should trust the number of the guy who actually designed and built the truck rather than some other person. That’s why I have only quoted Ford’s published numbers.
pxpaulx
Minnesota
Clearly I was misunderstood... Because I agree!
