- First Name
- Jack
- May 24, 2022
- Central NJ
- 2022 maverick
- Engine
- 2.0L EcoBoost
This posting addresses all replies So, my 245/70/17 bfg trail terrains do NOT rub. I have the 2" rough country lift. The only speedo accuracy I've checked is GPS comparison, which should be pretty accurate. At least I'd hope. And of course tire size matters,no matter what. Everything is affected. Yes the 245/65 are slightly smaller than the 245/70 but the tire design can make a slight difference also. An all terrain tire may have lugs that square off the tire, further out of the wheel well which could make it rub slightly. Every tire is a little different and if a fraction of an inch makes a difference for you, then you will be doing the trial and error thing.
