Aftermarket Options?
FutureOwnerInTN
Nashville
SUV/Car
The rumor is the Maverick will be on the Escape/Bronco Sport body on frame & suspension so that should allow for the aftermarket options that are existing/becoming available for mainly the Bronco Sport...right? If they offer more than just the rumored FWD. I like the idea of a slightly lifted Maverick with larger tires to set it apart from stock. These three [lift & smaller wheel/larger tire options] below look pretty good.
ALPHAequipt: Foxtrot wheels (17x7.5 / 5x108 / +35mm offset)
Ford Maverick Aftermarket Options? IMG_4001
MAD Industries: 1" Lift
1" front and rear equally
Front - 2 piece adjustable front space that goes between strut hat and Strut tower with extended length bolts.
Rear - 2 spacers lower under spring with custom lower shock extension bracket and extra Bolt.
Tire Size this 245/65R17 mounted on a 17x8 wheel with a plus 35 min
Ford Maverick Aftermarket Options? IMG_4003
Factory 1" lift in testing
Ford Maverick Aftermarket Options? 2021-bronco-first-ride-along-event-9-
FutureOwnerInTN
Nashville
SUV/Car
I think this lift/wheel/tire setup would look good on the Maverick...
Custom Bronco Sport by 4 Wheel Parts. Not able to find the specs on the lift/wheels/tires/etc...
Ford Maverick Aftermarket Options? Bronco_Moab_02
Ford Maverick Aftermarket Options? 4-Wheel-Parts-custom-Bronco-Sport-SUV_04
Ford Maverick Aftermarket Options? 4-Wheel-Parts-custom-Bronco-Sport-SUV_01
Ford Maverick Aftermarket Options? 4-Wheel-Parts-custom-Bronco-Sport-SUV_02
  • Like
Reactions: Doc
J_Garn
VA
2012 Ford Edge
I'm new to modifying vehicles, but I'd certainly be interested in raising a Maverick up maybe 1"/1.5". What kind of costs are generally associated with a lift kit? And is it normal to experience any issues by doing so/voiding warranties?
  • Like
Reactions: Doc
MarcusBrody
Nevada
Ford Transit Connect, BMW 318ti
Lifting a vehicle can void the warranty, but it depends on what fails. The Magnuson-Moss Warranty Act says that a claim can't be denied due to mods unless the mods are related to the failure. Now lifting a vehicle (esp. to add bigger tires) can add strain on the suspension and transmission, so I wouldn't count on warranty support for those areas if you lifted the vehicle/added tires bigger than stock or approved sizes. Someone might have more info on how Ford deals with this with Rangers and F150s, which are commonly lifted.
There are different types of lifts, some of which are more involved than others. The simplest basically just uses spacers where the suspension attaches to move it lower. You have to be careful to ensure the angles created aren't too far off from stock or it can cause premature wear on the CV joints and axles. I believe that Ford recommends you don't lift the Bronco Sport, but that's somewhat standard manufacturer rec as they don't want people messing with everything they've tested extensively. We will have to wait and see how those lifting the Bronco Sport end up before we get an idea of how it would work with the Maverick.
