Caleb@PandaMotorworks
Diamond Sponsor
Caleb
St. Peters MO
Check out our overview and installation video of the aFe Momentum GT Cold Air Intake System for the EcoBoost Ford Maverick!
aFe Momentum GT Cold Air Intake System (2022 Ford Maverick 2.0L Turbo)
Ford Maverick aFe Momentum GT Intake | Overview and Install [VIDEO] 50-70079d_1.1648051327 (1)
Ford Maverick aFe Momentum GT Intake | Overview and Install [VIDEO] 50-70079d_fc.1648051328
Pro 5R
DETAILS:
  • +16 HP / +18 lbs. x ft. Torque Max Gains
  • Outflows Factory Intake by 11%
  • Measured Flow: 316 CFM @ 7" H20
  • Washable and Reusable Pro 5R Air Filter for Maximum Performance
  • Innovative Filter-to-Housing Interface for Easy Installation
  • Clear Sight Window for Convenient Filter Inspection Without Disassembly
  • Premium Clamps and Silicone Couplings Provide a Secure Seal
  • Utilizes Factory Mounting Locations for an Easy and Secure Installation
Large Five Layer Performance Air Filter:
This 360-degree radial flow air filter features our pre-oiled Pro 5R media with five layers of progressively finer cotton gauze media for maximum performance. Our Pro 5R media provides your engine with the largest amount of high-flowing air, usually resulting in the highest power gains out of all our filter media options. This media is perfect for street and/or track use. Its inverted top makes for more filter surface area, resulting in longer service intervals.
Unique One-Piece Housing:
The smooth one-piece sealed housing, constructed of heat-resistant cross-linked polyethylene (XLPE), features our patented pending filter-to-housing interface. Its innovative design minimizes the total number of parts, making for an easy installation. A large, clear sight window allows for hassle-free filter inspection, without having to disassemble your system.
Dyno-Tuned Intake Tubes:
This system features high-quality, computer-designed, dyno-tuned intake tubes to achieve maximum power gains while maintaining a perfect fit. Its XLPE material is heat soak resistant and extremely durable.
Premium Components:
Stainless steel clamps are included for strength, and premium silicone couplings allow for ample flexibility. Momentum GT intakes are designed with fewer parts for a fast and easy installation.
Emissions Disclaimer:
This product is not currently CARB exempt and is not available for purchase in California or for use on any vehicle registered with the California Department of Motor Vehicles.
Pro Dry S
DETAILS:
  • +12 HP / +14 lbs. x ft. Torque Max Gains
  • Outflows Factory Intake by 4%
  • Measured Flow: 297 CFM @ 7" H20
  • Washable and Reusable Pro DRY S Air Filter for Maximum Convenience
Large Three Layer Performance Air Filter:
This 360-degree radial flow air filter features our oil-free Pro DRY S media with three layers of synthetic media for maximum convenience. Its progressive layering provides great filtration efficiency and dust holding capacity, while not requiring the use of oils. This media is best suited for street and light off-road use. Its inverted top makes for more filter surface area, resulting in longer service intervals
Premium Components:
LSchicago
Lloyd
IL
If true that's a pretty large gain for just an air intake and filter.
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
i think this one might be easier to install than the one i bought since uses 2 parts from the stock parts. very nice item
Charles
Charles
Georgia
'17 Edge
Way above my pay grade!
NycGoose
Devin
Cooperstown
Maverick, tacoma, bmw 325 89
Have this installed just been forgetting to take pics works great! Saving up for a catted dp to pair with next…
Schteve
Stephen
Danville Ca
2025 MAV Lariat
does the intake need and / or a tune or just bolt on?
Deleted member 30736
Guest
No tune required, I'm setting the Maverick up before tuning it. I installed one this week.
Ford Maverick aFe Momentum GT Intake | Overview and Install [VIDEO] 1000000350
Superg0
2024 XLT FX4 Azure Gray
S&B intake or this?
Nw_adventure
Salt Lake city
S&B intake or this?
S/B replaces the entire intake scoop in the front of the hood and upgrades the restrictive turbo inlet elbow. But I don't have direct experience with either.
Guest
The aFe doesn't replace the inlet but has a removable disc on the driver's side of the box to allow for more airflow.
